Question about Goodman PHKJ048-1 Air Conditioner
Why does it take 8 hours to cool our home? - Goodman PHKJ048-1 Air Conditioner
    Genius:
  • Goodman Master
  • 1,363 Answers
You have a 4 ton unit what square footage is your house.
Posted on Aug 12, 2015
Why does it turn itself off on/off.Thought it was a cooling issue.I unplugged for 2 hours.Tried again and within 15 mins it started turning itself on/off again.
definately sounds like an overheat problem .it might have a cooling fan in it contact the manufacturer thru their website .
Oct 23, 2015 | Audio Players & Recorders
Tip
Air Conditioning Programmable Thermostats - Great for Heating and Cooling
Programmable thermostats contribute to overall system performance, maximizing energy savings while providing complete comfort control. They also allow flexibility to homeowners because they can be programmed to match their lifestyle. Programmable thermostats save energy by turning down the cooling and heating system at night or at times when your home is typically unoccupied.
Did you know that properly using a programmable thermostat in your home is one of the easiest ways you can save energy, money. Homeowners can save about $180 a year by properly setting their programmable thermostats and maintaining those settings. They can achieve significant energy and money savings that are possible through the proper use of your programmable thermostat. Programmable thermostats do two things:
(1) Compare the thermometer reading of a room's temperature to the "ideal" thermostat temperature you select.
(2) Give start-and-stop commands to the heating or cooling system in order to achieve an indoor temperature that is as close to your "ideal" thermostat setting as possible.
Your savings will largely depend on the length of your energy saving program periods and the temperatures set. For example, an energy saving period of 10 hours with the temperature set back 10° will save more than a 5 hour energy saving period with the temperature set back 5°. By maintaining the highest or lowest required temperatures for four or five hours a day instead of 24 hours, a programmable thermostat can pay for itself in energy saved within four years.
A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home. The precise temperature control of a programmable, energy-saving thermostat saves wear and tear on high-efficiency heating and cooling equipment by properly cycling the equipment. A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home.
Controlling your heating more effectively could save you up to 17% on your heating costs. In fact, during the winter you can save about 3 percent of your heating costs for every degree you lower your thermostat. Begin lowering your heating bill immediately with the pre-programmed 7-day schedule, or modify the programming to suit your lifestyle. By delivering the heating or cooling when you need it, and optimizing temperature for activity, sleep and times you are away you can maximize your comfort level and save energy.
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3916016-honeywell_th8320u_thermostat
http://www.fixya.com/support/r3913560-honeywell_th8110u1003
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
http://www.fixya.com/support/r3898732-lux_thermostat_500
http://www.fixya.com/support/r3869033-replacing_thermostat
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3584298-air_conditioning_programmable_thermostat
on Dec 06, 2009 | Heating & Cooling
Why is my plymouth mini van transmission slipping? It refused to go into gear after running for half and hour yesterday, I shut it off for a half hour then went in gear and I drove it home ten blocks
The thing that stands out in your complaint is that you were able to let transmission cool down and then shift into gear. That points me to the automatic transmission cooler not functioning due to excessive heat either clogged,leaking,fan not operating, cooling fins packed full of debris all or one could keep fluid from remaining cool enough to operate gears correctly. Hope this points to something obvious for ya
Aug 03, 2014 | Plymouth Voyager Cars & Trucks
How to change heater core
THIS A HEAVY JOB, REPLY ME I CAN DO ON YOUR HOME IN FRONT YOU, VERY SHIPPER MY FLAT RATE IS 40.00X HOUR , LET ME KNOW IF IS GOOD PRICE FOR YOU, THIS JOB TAKE 4 HOURS, INCLUDE FLUSH COOLING SYSTEM IN FULL.
Feb 10, 2011 | 1999 Subaru Forester
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Refrigerator-lights on not cold
If has a electronil controlboard i would say it is faulty.Cheak on warranty.
May 11, 2009 | GE PSC23NGS Side by Side Refrigerator
Heating & Cooling Logo
48 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
