I have two sets of Ryobi 18v batteries. The older ones are all black. The newer ones have a black base with a yellow top. Originally, the older batteried charged without any problems. But now that I have started using both batteries, the newer ones charge and the older ones do not. When I put the older ones in the charger, the green and yellow lights come on and never go off (or change to red). I have three chargers and they all do the same thing. Do I need to replace all my old batteries?
-   I have the same thing happening to me. the green and yellow lights comes on and never go's off (or change to red). ????
-   Guest
Apr 14, 2009
-   I have two sets of Ryobi 18v batteries. The older ones are all black. The newer ones have a black base with a yellow top. Originally, the older batteried charged without any problems. But now that I have started using both batteries, the newer ones charge and the older ones do not. When I put the older ones in the charger, the green and yellow lights come on and never go off (or change to red). I have three chargers and they all do the same thing. Do I need to replace all my old batteries?-   haroldtoddhe
Had the same problem with some makita batteries, Was going to throw them away so decided to take apart and see what was happening. The are made up of 1.5 volt cells soldered together, found that many had .9 volts or less and others had 1.5 or more. This means that some of the cells had gone bad (probably due to lack of chemical reaction). Found that if I collected all of the 1.5 volt together could charge just fine. Problem is it is very hard to get them all soldered back together and even harder to enclose them. If a mfg. could come up with some way to change cells individually they could make a lot of money and save us a lot. So the answer to your question is buy you at least one more battery and recycle your old one.
One of the front power jacks will not work. The motor side works great. The orthe side the gear on...
(More)
One of the front power jacks will not work. The motor side works great. The orthe side the gear on the shaft from the motor turns and it also turns the gear that raises and lowers the jack but the jack does not move. Are thys a pin that has been sheared and can it be fixed?
I lent my Ryobi 18 V batteries and flashlight to a friend during a power failure. When they were...
(More)
I lent my Ryobi 18 V batteries and flashlight to a friend during a power failure. When they were returned, both batteries would not take a charge and the green yellow lights show on the charger. Are the batteries toast, and is the problem that they were charged before they had a total discharge?
Probably in the wrong cattegory but I need to find the tp2 mkv trailer pack- manual. As I want to...
(More)
Probably in the wrong cattegory but I need to find the tp2 mkv trailer pack- manual. As I want to know how to direct,the wiring off the pack to the caravan. Can anyone help? thanks denny
