Where is the drain on the norpole 10,000 BTU window sirconditioner nprac10keeg
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: 10,000 btu leaks water from
The drain must be stopped up. Blow air through it to clear the blockage.
Posted on Jul 23, 2011
How does this unit drain? I have noticed water pooling in the fan area and one small drop at a time coming from the bottom. I have a norpole window air conditioner 12,550 btu nprac10kewgz
-It could be loose drain plug, small crack in radiator some where.
-Test to find the leak location and fix or replace it.
Good luck
Mai
Jun 23, 2017 | Refrigerators
How do I correct the H3 code problem with the high pressure switch?
If unit shutting off on high pressure that typically means the out door fan is not cooling the compressor
Aug 20, 2016 | Norpole 12000 BTU Window Air Conditioner...
I purchased two Artic King 10,000 BTU Air Conditioners. The base of the units on the exterior of the building build up with water up to about 1 deep when it rains or running. Why is there no drain?
If you look inside the exterior part you should see a copper tube(part of the refrigeration tubing) that rests horizontally under this water. The water cools the freon inside that copper tube. That's why some models don't have a drain there.
Jul 30, 2015 | Heating & Cooling
Why when I turn my air conditoner on does it say FO
Good Day, whats the make and model of your air conditioner so we can assist you better. Check us out at Airbulance Reviews.
Jul 23, 2015 | Norpole 12000 BTU Window Air Conditioner...
FO comes on as soon as you turn it on. Why
F0 code usually Frequency 0 zero try shutting it down unplug for10 minutes. Make sure it is draining properly. Also fresh batteries in remote can always be a good ides
How long should i wait before installing & draining the drain plug?
The drain plug just allows the water condensate produced by the evaporator to be used to cool the condensor coils by 'flinging' it over the coils. This is done by a plastic ring around the fan at the rear of the unit - the 'Slinger' This makes the system more efficient but tends to collect more dirt and muck in the box and makes it rust a little quicker. Removing the plug will just allow the water to drain out. Either way, it will still work.
Mar 15, 2015 | LG 10,000 BTU Energy Star Window AC
Where is the drain plug on the Aew10anh1?
check levelness of unit top should be tilted towards back of unit
Sep 03, 2014 | General Electric 10,000-BTU EnerStar...
Remote control
buy a cheap universal remote for ac will do.
Jun 03, 2013 | Norpole 12000 BTU Window Air Conditioner...
Condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
Jun 25, 2010 | LG Electronic Window Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
