Question about Refrigerators
WHIRLPOOL GS6NHAXV001 ICE MAKER NOT WORKING
ICE MAKER CONTROL FLASHES 2 BLINKS...NOT PRODUCING ICE.
fridgetech
  • 473 Answers
SOURCE: Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Posted on Nov 07, 2007
  • 236 Answers
SOURCE: ice maker
poss a problem with a blocked filter?
Posted on Jan 20, 2008
  • 42 Answers
SOURCE: Light blinking on ice maker control switch
The red light on the right side of the freezer at the on off slide mechanism is normal and ok. I indicates the ice maker is not in a cycle at the time. It is not meant to tell the customer the unit is ok or it is not ok. Ignore the light.
If I helped enough please don't forget to rate as a FixYa if you need more information please request more help.
Thanks, supertechks
Posted on Feb 14, 2008
  • 1073 Answers
SOURCE: Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Posted on Apr 12, 2008
aasc
  • 1606 Answers
SOURCE: Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Posted on Aug 16, 2009
BROKEN INFRARED ICE CONTROL - ON WHIRLPOOL SIDE BY SIDE. CAN I REPLACE THAT PART?
The part you need to replace is 4389102 this comes with both boards and replace them as a pair. I have a question though, is the harvest fingers in the ice maker at position like a clock? Also to confirm the flashing of the light when the flap is depressed it 2 flashes and a pause? Not 1 flash and a pause, this means unit is harvesting and the ice maker should be moving and if not the ice maker could have a broken gear. This control unit could run you about 100 buck so make sure this is what you need before your purchase. Good Luck
Jul 28, 2014 | Whirlpool Refrigerators
Whirlpool how to install
With the freezer door open, depress the flap on the left. Does the flashing stop? If so, the Ice maker is the problem, not he optics. With the flap depressed is the only way you can test this. Solid light mean good, one flash and a pause means cycling, 2 flashes and a pause means faulted optics. Now for the ice maker, what position are the harvest fingers sitting at? At 2 O'clock the Ice maker is parked, At 12 it should fill with water so if the fingers are in any other position than 2 O'clock than the ice maker will not cycle at it can't. Its possible that the ice maker have a broken gear and will not function as designed. Get back to me if you need more information and a model number would be great. Good Luck
Jun 18, 2014 | Whirlpool Refrigerators
The Icemaker in my whirlptool side by side model ED5HVAXVL02 is not producing ice. The LED light just blinks Red. It blinks 2times then pause for 1 second. I have read that it means that the optics are...
2 blinks and a pause means your optics are good . Most of the time the ice maker is bad and needs replaced . Put about 2/3 cup of water in the ice maker and if it dumps , replace the water inlet valve AND check the black fill tube which fills the ice maker to see if it is frozen . If so , this is also an indication of a seeping ( leaking not closing completely ) water valve .
Jul 02, 2010 | Whirlpool GD5DHAXVY Stainless Steel Side...
Free standing ice maker not functioning
Have you got a slow flash or fast flash?
A slow flash is a problem with the sensor.
A fast flash is dirty condenser failed condenser fan.
See page 16
Mar 15, 2010 | Kenmore 51lb. Clear Ice Maker
ICE MAKER
Your ice maker works off a different side than the water dispenser. Most times the water control valve is the problem yet it has 2 sides one for water and the other for ice. You can check the ice maker by filling with tap water. Let it freeze and if it dumps the ice and tries to refill I would say the water control valve part number 4389177 will need to be replaced. Sea Breeze
Aug 24, 2009 | Whirlpool GD5SHAX Side by Side...
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Flashing red light on ice maker control
Hi
I have Kitchen Aide refrig. Resently, we had a power surge which seems to have done something to the ice maker control. immediately after it stopped making ice. It has since started to make ice but very slowly. Before the controller blinking red light blinked and paused steady. Now, it blinks two red and pause steady. Is this repairable?
Thanks
Jul 16, 2009 | Whirlpool Refrigerators
Icemaker not working, infared sensor is blinking
We had the same problem. There are 2 sensors on either side of the door, the one that is blinking and the receivor on the other side of the ice bucket. We ordered a new sensor from www.appliancepartspros.com -part #4389102. It came in at 2 days and was really easy to fix. Of course, there is a black rubber tube that adds water into the ice maker from the top of the fridge that froze over. Once we defrosted that, our icemaker worked again.
Nov 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
