Question about Fish
Water pump noise - Fish
How to fix a noisy water pump on a grand jeep Cherokee 2007 3.00 deseil
a noisy water pump ( low growl or rumble noise) is a problem bearing and the cheapest fix is a new water pump
squeaks or other high pitched noises can be tested with soapy water on the belt--noise will stop for a short period of time
If the water pump housing is cast iron, you may be able to get a repair kit for the pump but the cost of the kit and the labor to do the job is generally around the price of a new pump
Dec 10, 2016 | 2007 Jeep Grand Cherokee
There's a sound like a bad bearing coming from the water pump but no water coming out of the weep hole. i'm guessing the pump is bad. is this common for this car?
Bearings on a water pump failing on any car is a common problem! The water leaking from around the water pump area is the tell tale sign.........get it checked out and replaced as soon as possible to avoid further damage to the engine.
Oct 14, 2015 | 1993 Geo Prizm
How to tight the water pump
belts squeak or squeal if loose or worn . water pump bearings will give a low grumble like marbles in a drum. you cannot adjust a water pump only the belts to it. if the noise is a grumble then the fix is a new water pump unit.
Feb 12, 2015 | 2002 Nissan Xterra
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
1994 bonneville 3800 engine. I had work done, replaced water pump, and now I have a noise that sounds like a screw or a stone bang around on metal. I took off the serpentine belt and ran the engine for a...
If you had no noise prior to replacing the water pump then the noise will be at the water pump. Remove the belt and turn the water pump by hand and you should feel the noise. I suspect fan bolts too long or water pump bolts not fitted in the proper holes and hitting on the pulley. If the problem can be felt in the shaft of the water pump I would take it back to whoever fitted it and have them re do the job as it may be that the impellor is hitting on the inside of the engine housing water jacket.
Aug 25, 2013 | 1994 Pontiac Bonneville
Water pump c220 seris
A water pump is a device used to move liquids. A pump displaces a volume by physical or mechanical action. Water Pumps displace fluid, causing a flow. Adding resistance to flow causes pressure. A sump pump is a water pump example. ---------------------------------------------------------------------------
Godiag T300+
Nov 23, 2012 | Mercedes-Benz Cars & Trucks
I took my 2005 Chev. Malibu in for an oil change and now it is making a loud noise from the engine. they say its the water pump? is that possible?
  • Hi, I can help.
  • When your water pump goes bad it will begin to grind. I had one I let got far to long and it sounded deafening when I opened the hood. You can open your hood and listen and see for yourself. The water pump is on the belt line, left side under the hood, last pulley toward the rear.
  • Now if your asking can an oil change effect the water pump? No, not at all. Water pumps go sporadically.
  • It would be odd that you heard no noises before the oil change and now the water pump is loud enough to take notice after the oil change. The bearings usually go a little slower than that.
  • I would be interested in some more of the details to this. And what your overall concerns are. I'd be happy to further. help. Otherwise get a second opinion on your cars condition.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 22, 2011 | 2005 Chevrolet Malibu
Knocking noise exact location
grab water pump with both hands and see if it wiggles if it does its bad.bearing is worn.
Oct 08, 2009 | Buick Park Avenue Cars & Trucks
Makes loud noise every time water flows into it
If the water is a banging type noise in your piping this would be water hammer the sudden stop of water within the piping. If the pump is making heavy noise (like it is pumping gravel) this is typically due to lack of NPSH (suction condition) If this is the case you may be lifting the water too high (suction lift) or the pump is trying to pump too much. In this case throttle a valve on the dischage side of the pump to help bring it back in to an are where as there is enough NPSH (Net Positive Suction Head)
I hope this may have helped,
Tom
Jul 15, 2009 | Plumbing
Fish Logo
245 people viewed this question
Top Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Fish Expert? Answer questions, earn points and help others
