Question about Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer ()
How do I take the head off a straight shaft mode 316791191
My poulanpro weedeater head won't turn
bent shaft --- damaged drive cable kinked and jammed
straight shaft --- head gears problem
Jul 16, 2016 | Poulan Garden
Why does the head stop moving?
with trimmers , there is a shaft or as in a bent shaft a cable that has square drives and ends
these can become oval or break off if continual heavy loads are applied to the cutter head
next there is a centrifugal clutch at the top of the shaft and if continually used in heavy work that clutch will wear out and not grip sufficiently to drive the shaft
most cutter heads do not suffer problems other than to get loose and work down the tube thereby allowing the square drives to part
Jun 24, 2015 | Craftsman WeedWacker Gas Trimmer 25cc...
What direction does a weedeater head supposed to turn?
I have the yardworks curved shaft which is virtually identical to yours and it turns clockwise. Unless the straight shaft changes things but I do not think so.
May 30, 2015 | Craftsman 29CC Straight Shaft 4-Cycle...
Fixing straight shaft attachment on Troy-Bilt string trimmer
Here is a link to sears parts direct. You can see prices for all parts and make a decision from that.
TROYBILT Trimmer Boom and trimmer Parts Model TB75SS
Aug 16, 2014 | Troy-Bilt Tb75ss
How do you take off the nylonhead off a srm 225 straight shaft trimmer to put on a new one
The nylon head should pop off by clicking on two pins holding it to the main body. Once it pops off you should be able to reload it and push back to those clips again
Aug 14, 2014 | Echo Garden
Not sure what you mean but if you are saying the weedwacker head is not engaging it may be the cable that goes from the motor to the weedwacker head and runs down the inside of the shaft.
May 24, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
My weed starts easily but the cutting head will not rotate
you need to check and make sure the head is installed right ,, if it is sounds like you need shaft and see whats not turning and replace,, hope this help
Jul 06, 2013 | Craftsman 27cc 2 Cycle Crank Straight...
How do you change a head on a poulan pro trimmer
Just below the gearbox there is a slot and when you turn the shaft there is a slot on the shaft that lines up with that one. Stick a screwdriver in the slot when they are lined up and then grab the head and turn it clockwise. (the threads are reversed)
Apr 22, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer () Logo
43 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
