Presidian FOLD UP AMPLIFIED SPEAKERS PPS-1471 manual
The flywhee on my pfaff 1471 seems to have disengaged after unsuccessfully winding a bobbin. The motor goes but the needle does not go. What to do?
Did you turn the knob inside the hand wheel backwards while holding the wheel itself? If that knob is in the correct position, did you hear it snap into place when you rotated the hand wheel towards yourself? Does the needle bar move up and down when you rotate the hand wheel?
I suspect that the needle bar is still disengaged from the motor mechanism. The manual is available from Pfaff on the creative 1471 page: http://www.pfaff.com/en-US/Machines/creative-1471 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/creative1471-manual-EN.pdf . See page 13 of the PDF for the picture of the direction and position of the knob that should be checked.
If the machine still doesn't work, it may be that the belt is bad. This connects the shaft of the motor to the mechanism that runs the needle bar. You can find a parts list for the 1471 here: https://www.universalsewing.com/tek9.asp?pg=parts_pfaff . Scroll down to find the various 1471 diagrams. The belts are probably available at most Pfaff or other sewing machine dealers. This page, https://www.sewingpartsonline.com/pfaff-1471-sewing-machine-parts.aspx , is one source. You want the motor belt.
I hope this helps.
Apr 07, 2018 | PfaFF Sewing Machines
Pfaff 1471 threading instructions
Hello Patricia P. Thomas
Download a free Pfaff 1471 Manual here
https://www.manualowl.com/m/Pfaff/creative-1471/Manual/333543
The threading instructions are quite simple to follow.
Please let me know how this works out for you.
Happy Stitching
Feb 27, 2017 | PfaFF Sewing Machines
Presidian phone manual
What model Presidian phone?
Dec 05, 2013 | Lands Phones
I have a 1997 Dodge Ram 2500 4x4 Diesle 5 speed manual I have a factory radio with 6 disc. changer the radio works and so does the cd changer but I get very little volume Im sure its a amplifer problem....
To determine how your speakers are amplified you will need to know what speaker package is installed.
Usually Laramie editions come with Infinity speakers.
If I remember correctly the Infinity speakers have appliers on them.
My dodge truck is a year 99 2500 series, and I have already had to replace the door speakers. I used the cheap Walmart speakers. (6x9) They fit well enough.
Note: If your truck came with amplified speakers, non amplified speakers will only push what your radio can provide it in Wattage.
May 02, 2011 | 1997 Dodge Ram
I purchased a new Gateway. I can faintly hear the
Other than setting the volume controls in the software, make sure you plugged the speakers into the proper jack. Sometimes there are several output jacks, there may be a line out as well as an amplified out. If the speakers are not amplified, and there is an amplified out jack, try that one.
Jul 27, 2009 | Audio Players & Recorders
Want to download a user's manual
Probably the website for Presidian....or search google with that same question, I'm certain you'll find something.
Apr 23, 2009 | Lands Phones
The volume is too low on my computer speakers
Hi, Mark Here, see I can help.
The 1907 does not amplify your sound it will let you control the volume to some degree but not boost the incoming sound.
If you had amplified speakers b4 your sound card requires amplified speakers.
Best two options i can give is.
  1. If it is a desktop you can install a amplified sound card. Hook to monitor speaker.
  2. Unplug monitor speaker &use amplified speakers.
Just so you know laptops use internal amplified speakers. If you decide to install sound card make sure it is an amplified card.
Hope that fixed ya! know not the best news. Need more help comment back. Please Rate.
Good Luck!
Mar 28, 2009 | HP w1907 LCD Monitor
I need a manual for a presidian pdr 3222. Can you e-mail one? Carl
download manual from>>
http://club.cdfreaks.com/f89/presidian-pdr-3222-manual-discrepancy-220252/
Jan 16, 2009 | Radio Shack 15-2142 Remote Control
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
