Hi I have a 54cm Sansui number on it SV21E11G multi system and remote written RC06E it it shows ASM after 3 seconds then starts doing auto tunning all channels over and over again without me pressing the remote or bottons
Pookeybrain
  • 51 Answers
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Posted on Nov 10, 2007
SOURCE: Sansui 54cm TV zoom
push the pip buttton
Posted on Feb 24, 2008
  • 8 Answers
SOURCE: Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
Posted on Aug 21, 2008
SOURCE: how to run channel auto scan
Okay here's how you do it. Sadly they buried this DEEP in the user guide and I stumbled across it -
Press the TV Menu button then with the < or > arrows scroll to the Channel menu. From there you can select the auto scan.
Posted on Jan 10, 2009
SOURCE: finding AV channel without a remote control
get ewf 2004 on av channel without remote
Posted on Feb 19, 2009
Sansui sv2918
Main system control memory IC fault. Replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 29, 2014 | Televison & Video
Asm after 3 sec
Automatic Search Memory [ASM] fault must be due to a defective system memory IC. Replace it.
Dec 18, 2012 | Sansui Televison & Video
Sansui tv asm after 3 sec error
Replace its system memory IC.
8 solder ic number for tcl falt tv
Can you please check for any jammed buttons on the remote and/or control panel? Try switching on the TV manually, while removing the batteries from the remote. If you notice same problem, the area to be looked into is around the system control area: like dry solder, leaky/dry capacitors and this should be done only by a qualified service technician.
Aug 25, 2012 | Televison & Video
How to unlock ASM in SANSUI SV-2010K
Hello
Universal remote codes for Sansui TV with RCA RCR311B remote control are:
1020, 1054, 1133, 1145, 1167, 1230
But I really don't understand to what do you mean by this ASM lock. ASM [Automatic Search Memory] is meant for tuning fuction. When we put the set to ASM mode, it should search all the available programmes at that time at appropriate chanels, and will stop; must stop; at the end of the tuning is over, and must show the first received programme. Then we can change the programmes as our own select. If ASM function does not works with your TV as specified above, surely its memory IC is in trouble; damaged; and should replace it with same type and number. This IC is an eight terminal one, can be located very near to main system control IC of your set. OK.
Aug 08, 2011 | RCA RCR311B Remote Control
/my screen is blue with video 1/auto showing on the top right hand corner, how do i sort the pro out.
i need more info?
The video1 is the input channel ,the auto is the sound and video system the tv uses to identify the signal(you have a multi system tv) {multi system (pal,ntsc,secam etc) if it is in auto mode you dont need to worry about it , the tv wil identify the system automaticaly and set the apropriate setings by itself.
You could press av on tv or on remote to switch between av1 /av2 /tv program etc, make sure the ant / dvd / cable etc is conected and on while selecting / pressing av button.
hope it works.
Apr 20, 2011 | Sansui DTV2760 27" TV
Remote (2) works to tun the TV on and off.... But nothing is working in the SAT mode. Remote (1) is working fine.
Hi, Mary with Dish Network Customer Service. I am sorry you are having a problem with your TV2 remote. It sounds like it needs to be readdressed to the Dish receiver box. Take the remote to TV1, using TV1 remote, press the "Menu" button twice. TV screen should show "System Info", towards the bottom of the screen it will say "Primary Remote Address" and "Secondary Remote Address". Take TV2 remote, press and release the "SAT" button, on the top left corner of remote. The press the "Record" button 3 times. The number in the white box, next to "Secondary Remote Address" should have changed, if not unplug receiver from power for 10 seconds and then follow the instructions again. This should resolve your issue but if you are still having a problem, you may need to contact Tech Support directly. I hope this helps.
Jan 04, 2011 | DISH Network 135899 Remote Control
We understand that your problem is: remote of sansui SV-2110k has been damaged, now some channels are automatically locked and favourate hasbeen activate so only two there are available, ASM tuning...
Not possible without a remote and the secrect codes u enter.Try website Remotes.com to buy an exact remote or very close to the original remote.
Dec 11, 2010 | Sansui Televison & Video
Tuning without a remote
pls use panel menu key prees and select tuing menu and see display in ASM [auto serch memory] select ASM befor ch.no set is "0" and select ASM .
use panel ch+ ch- is up and down select key is v+ and menu key is menu next page
Oct 08, 2009 | Televison & Video
Sansui 54cm TV zoom
Nov 08, 2007 | Sansui DTV2760 27" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
