Caira tv lcd 42
The led goes from red to yellow to green then red again and not working
  • 8 Answers
SOURCE: .lcd tv not working
cold solder on micro panel fixed mytv
Posted on Jul 08, 2008
mumma_1
  • 903 Answers
SOURCE: 42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
Posted on Oct 23, 2008
  • 4 Answers
SOURCE: Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Posted on Feb 14, 2009
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
  • 8457 Answers
SOURCE: LG 50 IN. PLASMA TV MODEL # 50PC1DR . POWER
Power supply board is dead,replaced the power supply board will get power.
Posted on Jan 27, 2010
Im trying to connect my sega dreamcast which has red white an yellow av cable only, however my insignia NS-32E570A11 led tv only has for component connection with the blue green n red, when i hooked it up,...
Sorry, this will not be easy....
You need to locate a composite to RGB converter box.
Your Sega outputs a composite signal - Video (yellow) and audio left/right (white/red).
The TV needs RGB (red/green/blue) inputs on the component connection...your composite signal divided by three. There are converter boxes out there for around 70 bucks or so.
Are you certain you do not have a yellow VIDEO IN jack on your set? Every LCD and LED TV I have experience with has at least one.
Feb 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
When hooked up led 46" aquos it is black and white
You must only connect a yellow to a yellow a green to a green and etc. You must have a yellow cable going into a green hole. You need an adaptor. The adaptor goes into input 2. The other side of the adaptor is a yellow red and white male cable that will fit into your device.
Sep 28, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LED goes from red to green then back to red, when
led goes from red to green and back to red when turning tv on
Dec 27, 2009 | Proscan 19LA25Q 19 in. LCD Television
Problem for Sony Grand WEGA KF-42SX300 42 in. LCD TV Only goes from red to amber on led
hello try a factory reset. turn on the tv while holding the reset button on the remote control, press the power button on the tv, the tv will turn itself off and back on again release the reset button
shaun
Nov 02, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
it was to do with a faulty freeview box replaced it everything now works tv was not at fault
Jun 17, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
