Question about Drills
Bosch csb 550 re
Problem with reverse mode
2 Suggested Answers
SRF518
  • 232 Answers
SOURCE: replacing carbon brushes of csb 500 re bosch drill
bosch brushes are unique. they have a spring embedded in the carbon so when the length gets too short, the spring lets go and raises the brush above the commutator and the appliance stops. you need to remove the handle partially or the brush covers and unscrew the brush holder(s) two small screws secure the brushes and holder to the appliance.
Posted on Oct 13, 2009
My Bosch CSB 650-2RE works fine when drilling horizontally, but as soon as it goes vertical the power goes off, even though switch is still depressed
You probably have a loose wire at one on the connections inside the unit. Open it up and have a look at all the connections, pay special attention to any push in connections as they tend to get loose over time.
Mar 02, 2015 | Bosch Drills
How to operate torque control on CSB 550 RET drill
No torque control on this model.
Feb 13, 2015 | Drills
My bosch csb 550 re, is not working while i'm using it, i already changed the carbon but still not working and the reverse switch stock up. pls help me. thanks
Have you check the continuity of the wires through the drill? Try contacting www.oasistools.com for help
Mar 05, 2014 | Drills
Csb 500 re
the ancre and / or a part of the electric field damaged. drivinggear must be replaced if ancre was gone too , but in most cases its not worth to repair if it has its working hours on it.
Feb 13, 2014 | Bosch Drills
Bosch csb 550 RE only works in the vertical position
10th March 2013. I experienced the same problem with my Bosch drill. Yes, it also only worked when held in the vertical position. I pulled the drill apart. In my case, the problem was right at the base of the drill where the electrical cord and the drill meet. In that area, there is a flat piece of hard plastic which holds the cord securely in place. This is held down by two screws. Directly beside that is the rubber attachment that hold the drill chuck. Well, right in that spot, there was a gaping hole in the wiring (refer attached photo). It will not be seen, unless you, or a service agent, pull that area apart. Anyway, I shortened the cord, secured the wiring again, and the drill works perfectly. Good luck. Ted.
Nov 16, 2012 | Bosch Drills
On my BOSCH CSB 470-RLE 470w electric drill the chuck is slipping i can hold it in my hand and it wont move
It is a spring loaded hammer drill. You need to push the chuck down just a bit for it to engage the clutch. If it is still slipping then either the clutch pieces (items 23 and 32) are worn or item 32 is spinning freely on the spindle shaft. Here is a parts diagram.
Bosch CSB470-RLE diagram
Aug 16, 2012 | Bosch Drills
How do the wires go on a bosch CSB650 drill
If you mean the R/l switch attached to the top of the switch. The wires from the brushes go to diagonally opposite connections and the field leads in the others. If it go slow in forward motion swap the brush wires over with each other.
Jun 07, 2012 | Bosch Drills
Replacing carbon brushes of csb 500 re bosch drill
Oct 13, 2009 | Bosch Drills
Drills Logo
42 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
