Question about GallienKrueger Gallien Krueger 800rb
Takes a while to turn on
When I turn on the amp, all the lights come on but no sound, and it seems that the only way to get to produce sound is to pluck the strings on the bass very hard and then it starts playing right away. I was thinking that there was a warm up time on the amp but the times between powering on and sound coming out is not consistant. anyone else have this problem, and yes I have tried it out on different basses.
2 Suggested Answers
  • 5603 Answers
SOURCE: Last weekend while I was playing, I smelled that
They are NOT called motherboards, just circuit boards.
Sometimes the board can be restored by carving out the black and re-insulating it and repairing the cause and bad components.
Likely the power transistors have shorted that are associated with that side and burned compnents.
Many shops will only replace the whole board rather than do the labor to restore the board... Yes, either way it will be expensive to repair.
Causes of these failures can be overdriving the amp. bad speakers and or cables. Loose speaker connectors that vibrate can lead to this.
Another problem can be if SUPERSONIC (can't hear it) feedback is occuring at high frequencies that overloads the amp.
Posted on Aug 09, 2010
MC600 Electone. Why no sound, no lights?
Start with the power supply and make sure all connections are properly seated. If you are not familiar with this type of work please have a professional look at it. Working with electricity is very dangerous.
Apr 19, 2016 | Yamaha Music
Power on have no light but there is a slight hum. Plug in guitar nothing happens.
You didn't tell us the make and model of what I'm assuming is a guitar amp? If it doesn't light up and doesn't produce sound it seems like you have blown a fuse. However, fuses blow for a reason and you should take it to a repair shop.
Oct 23, 2015 | Music
No Power after Valves glowed bright
This could be a transformer failure. Take it to the repairs shop.
Jun 08, 2013 | Peavey Valveking Vk100 Guitar Head
No sound. Screen face lights don't light up. All tubes glow when powered on. The speaker pops when coming out of standy-by into full on state. But absolutely no guitar sound, no auxiliary input sound, ...
If it is within warranty take it back to the shop. If not then its going to need an engineer to look at it. Its not worth fooling around inside a tube amp as the capacitors can retain lethal voltages even when unplugged.
Sep 16, 2011 | Peavey Vypyr Tube 60 Amp Combo
I bought an Orange CR35LDX combo amp last week along with a new Cort guitar and a new Ibanez guitar cord (cable). When i plugged it in my room to try it out, the amp produced a weird humming sound. When i...
Maybe your room is wired without an earth connection. Try it in other rooms or a friends house. If it works OK elsewhere, you need an electrician to check out your house, it may be dangerous. If it still does not work, look at your settings, and use low gain for testing.
Jul 01, 2011 | Orange Amps Orange CR35LDX Amp Combo
Have BBE Acousimax pre-amp. Clip light is on and will not turn off. I have not power through the unit but power source seems ok. Fuse problem?
This device, unlike most guitar pedals, requires a 12 volt power supply. Are you sure yours is the original? If the supply is low, the internal electronics will show clipping. Make sure you are using the original power supply and if so, check the voltage it is producing.
May 16, 2011 | Bbe Acoustimax Sonic MaximizerPreamp Pedal
I have a Fender Frontman 212r amp. The problem seems to be when I put the volume upto past 4/10 [40%] The amp gives out an awful crackling sound and power light etc flickers on and off. I have had the map...
When i turn on my 212R it turns on in drive channel. if footswith is plugged in, then it turns on in the clean channel, but after switching in drive it is impossible to switch it back in clean channel. What could be wrong? Swith position doesnt change anything and it seems like switch is OK.
Nov 27, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
Hi Folks - I have a Roland Fantom G6 that produces no sound! Everything else seems to be fine - the display registers that I am hitting the keys & even the skip-back sampling feature produces a wav...
This probably is not a DIY repair... The audio comes out of the CODEC and is buffered by Op Amp used as filters and then goes through the volume controls, After that it goes to the jack board with buffer OP amps. First thoughts might be a damaged volume control, however, the "B" outputs don't go through volume controls...
About the only thing I would think you could do is to CAREFULLY open the unit and look for a loose cable involved with sending the audio to the volume control panel and then the cable that takes the audio to the jack board...
More than that you would probably need to take it to a shop equiped to troubleshoot.
Nov 23, 2010 | Roland FANTOMG8
SWR WorkingPro 400 watt head - no sound, Preamp Clip red LED is continually lit, Limiter green LED continually lit - fuse is perfect. It worked for a few minutes, then just stopped.
Since the PA clip is not lit, the problem seems to be up front...
First thing is to look for a bad cable as a broken ground could be putting hum at a clipping level. First thing, test this by unplugging all inputs. If the clipping light goes out, then you have bad cables or a ground loop.
Try sending a line level signal into "Effects return" to test if the power amps are OK.
If the clip light is still on, turn all gain controls down to minimum. If light is still on then take unit for servicing.
May 31, 2010 | SWR WorkingPro 15 200 Watt 1x15" Bass...
Amp volume is irregular, jumpy, and produces a muffled tone
SOunds like the emulated line out is the problem IT may be defective. Is this a button or a knob? It may have dirty contacts and MIGHT be able to be cleaned with electronic contact cleaner.
Oct 04, 2009 | Music
GallienKrueger Gallien Krueger 800rb Logo
20 people viewed this question
Top GallienKrueger Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a GallienKrueger Music Expert? Answer questions, earn points and help others
