Question about Gift Mark Deacon Style Bench & Toy Box on Casters Cherry
At first time assembled, Lid on toy chest does not close all the way down
Igloo chest freezer 7.2 cubic ft seems running all the time?
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
Apr 30, 2014 | Igloo Cooler Igloo - 5.2 Cu. Ft. Chest...
Should I buy a toy chest with or without a lid?
Both of these options have their own advantages and disadvantages. Personally, I prefer the way toy chests with lids look. If you opt to buy one with a lid it is important that you ask a few questions for your childs safety. The last thing you want is to have your child climb inside and get trapped. Look for one that when the lid is closed there is a gap between the lid and the box.
Aug 14, 2012 | Furniture
Every month I clean out my childrens toy chest and it seems to be more cluttered than the last time. I would really love to get it more organized. Can someone recommend a good way to organize a toy...
I recently organized my childrens toy chest and so far, it has stayed pretty controlled. Here's what I did - first empty out the box and divide the contents into categories (plastic toys, dolls, etc.). Next you will need some plastic containers with lids that will fit inside the chest and are stackable. Place the sorted and categorized toys into their designated boxes and stack inside the toy chest. You can make it an arts and crafts project with your kids to decorate the plastic bins so that they know what belongs where.
Should I store my childs toy chest in the yard?
It would not be good to store your toy chestin the yard unless it is completely waterproof or has been treated to protectit from the sun. Many of the modern plastic toy chests could be stored outdoorsbut you should ensure that no water can get in and damage you child belovedtoys.b>
May 29, 2012 | Furniture
Should I put some air holes in my childs toy chest as I worry that he may climb into it?
If you are worried that you child may climbinto the toy chest and get trapped then it would be a good idea to take someprecautionary measures to ensure that your child would be able to breath or getout of the chest without any trouble.b>
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Apr 18, 2012 | Woods Chest Freezer C1501W3
1997 cadillic sts trunk lid will not latch to close. i don't have a shop manual for the car and am not sure where to start. a 20a fuse labeled pull down in trunk is o.k. have not used dmm or test light to...
Do you mean the pulldown is not working, or the trunk lid latch is not connecting to the pulldown assembly when you try to close the trunk?
This latter case typically happens when someone slams the trunk lid down several times not realizing there is a pulldown system and thinking slamming it will make it close (this often breaks something). Check the latch on the trunk lid - if it's in the closed position, use the key to try to move it to the open position and try gently closing the lid again.
If not, there is also a switch on the pulldown assembly that starts the pulldown motor when it is depressed by the closing trunk lid - you can also check this to make sure it's working. Otherwise, either the latch or the pulldown assembly has been bent/broken.
Jul 14, 2017 | Cadillac STS Cars & Trucks
Gift Mark Deacon Style Bench & Toy Box on Casters Cherry Logo
489 people viewed this question
Top Gift Mark Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Gift Mark Furniture Expert? Answer questions, earn points and help others
