Question about Whirlpool GEW9250 Electric Dryer
I have an E3 error code on my diagnostic run for my Whirlpool Duet Dryer.
What can I do to repair my dryer when it shows an E3 error code? We ran the diagnostic tests and this code showed up. My dryer stopped working yesterday. All of the lights came on fine, but all I would get was a beep when I tried to start it? Can you help me fix it?
Illeagle
  • 525 Answers
SOURCE: whirlpool duet dryer - PF error
Here are 2 good ones from very large inventory companies
http://www.apdepot.com/index.asp
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 27, 2008
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Steam Dryer Beeping
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$%^
Posted on Sep 30, 2010
  • 3074 Answers
SOURCE: Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Oct 19, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Tip
    Whirlpool Calypso Dryer Error Code Explanations And Repair
    Failure - Code Condition - Check/Repair
    PF - Power Failure - If the household power goes off and the control board was in RUN mode or PAUSE mode, the electronic control board will display a power failure error code.
    E1 or E2 - Thermistor Failure - The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
    • When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
    • When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
    Normal thermistor resistance values:
    • 60 degrees F. - 15.3K ohms.
    • 70 degrees F. - 11.9K ohms.
    • 80 degrees F. - 9.2K ohms.
    E3 - Touchpad or Software mismatch - Flashes when there is a touch pad or software mismatch.
    • This error code is displayed only in diagnostics mode.
    on Jul 19, 2010 | Washing Machines
    Duet model GEW9200L. What does code 08 indicate?
    there is no such error code on this dryer, that is likely the time left on the display... If the dryer stopped at the 8 minute mark with no error, check the door switch because it can interrupt a cycle, but will result in no error... Did you try to start it again, what happened? Whirlpool Dryer Main Control Board WP8546219
    Jan 15, 2016 | Whirlpool Dryers
    Fh error code wirpool duet washer
    Display shows F20 or FH - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...fh-front-load-...
    Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
    whirlpool duet error code FH - Appliance Repair Forum
    forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
    Jan 5, 2009 - 10 posts - ‎1 author
    ... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
    1 post
    Dec 5, 2014
    Whirlpool Duet Washer HF Error Code
    Jun 10, 2013
    FH Error Code on Whirlpool Duet Washer
    Mar 11, 2013
    FH error code
    Sep 13, 2008
    More results from forum.appliancepartspros.com
    Stumped on error code FH for Whirlpool Duet front load washer .
    Jan 08, 2016 | Washing Machines
    Everything appears normal,,, when we hit start it beeps however it does not start, there is not an error code,, the time of dry remains in the display
    Just ran into the same problem with our Duet electrical dryer, also the courtesy light blew out when this all happened. Has anyone given you repair/ reset ideas?
    May 08, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
    Error code pf
    PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
    Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
    Whirlpool dryer mod. wed9200sqd wont star i did a diagnostic test i got a error P3E on my screen. please help.
    i tried looking up your code,the closest thing i could find was a E3,says it's for a calypso dryer,it's the touch pad and you can only see this in diagnostics mode,hope this helps,also i couldn't find your model number,there isn't a D in them
    Nov 29, 2009 | Whirlpool Dryers
    I have Whirlpool Duet dryer,model GEW9200LQ0. At first, it would stop drying when I set it on a particular drying mode (permanent press,delicate, etc.)but it would stop before the clothes were dry. Then,...
    It appears your timer/main controller/CCU has failed in this instance.
    For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
    I recommend both sites because ...
    FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
    PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
    RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
    If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
    In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
    Anything too complicated or beyond your scope should be handled by a professional.
    If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
    Sep 17, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
    I have a Whirlpool Duet electric dryer M# GEW9200LW0 that won't move past the sensing function on any cycle
    try running a diagnostic on the dryer. You do this by making sure the power is off. Then push one of the sensor buttons (not the pause/cancel)
    hold for 3 sec.
    let go for 3 sec.
    hold for 3 sec.
    let go for 3 sec.
    hold for 3 sec.
    the lights will come on and 88 will show in the LED window. Then it should give you a F code.This website has a list of the codes and other instructions. http://fixitnow.com/wp/2007/06/19/whirlpool-duet-sport-dryer-diagnostics-and-fault-codes/
    I ran the Diagnostic and it reset my machine and now runs fine. ( I had F-02) stuck button.
    hope this helps
    Jan 14, 2009 | Dryers
    Whirlpool GEW9250 Electric Dryer Logo
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
