Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Picture shakes Within the last year the picture has started to shake regardless of the input source. How can I fix this?
    Genius:
  • 1,153 Answers
Loose connection in video area, look for soldering points loose
Posted on Aug 27, 2007
SOURCE:
Picture shaking and skipping
not much information here, first look to see if same issue when using rear video/audio inputs. Then try to describe what it looks like or TAKE A PHOTO AND POST IT HERE.
Dec 15, 2012 | Panasonic PT-51HX40 51" Rear Projection...
Picture is shaking
try to play any input on audio/video like dvd etc..
If the problem still there you have signal board problem
Nov 08, 2012 | Mitsubishi Televison & Video
Sony dslr a100 shaking and making noise
ISO speed is too high, low an iso as possible go to the menu, and read your owner manual very well, and fix it.
God bless you
Sep 22, 2012 | Sony Alpha DSLR-A100 Digital Camera
Toshiba 30HF84 Picture Doubling and Shaking
Check its main power regulator section for any faulty capacitors.
Sep 01, 2012 | Toshiba 30HF84 30" TV
I have a HLN617W Samsung television. The picture shakes bad. When I put it on pip where you can watch 2 screens at one time, on the left is real shaky and the right is good for about 20 minutes and then it...
Two boards can cause that kind of problem in Samsung HL-N617W, either power supply or digital board.
Need to swap above said boards to confirm what board is causing problem or inspect closely for leaky electrolytic capacitors and replace them with same ratings.
Hope this info will help you.
Thanks.
Nov 15, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Abrupt loss of picture during DIRECTV-source
Ur main video backllight board it dying,must be replaced.
Oct 14, 2009 | Fujitsu Plasmavision PDS-4209 42 in....
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
TV picture shaking!!!
You have a Hyper module problem.Very common with these chassis.Toshiba part # 23148024.This part is no longer available,but it can be repaired.I dont know how much electronics training you may have but it`s a pretty detailed job.The hyper board is the silver stand up module inside the unit right behind the external Audio/Video jack panel.There are 11 little capacitors that all need to be replaced.The value of these caps are 10uf @ 16VDC.I do this job for about $245.00 and the unit works fine.Check with your local shop if it is too much for you.If you don`t know what you are doing you can ruin this module then it`s time for a new set.Good luck.
Jan 15, 2009 | Toshiba 42H82 42" Rear Projection...
Help! my camerra is shaking!!
Sell the piece of junk and by something reliable like, apparently, Panasonic or Canon..
I have had exactly the same problem on 2 Sony compacts within 12 months, advised them, complained and they don't appear to give 2 $%*?'s.. Fortunately just inside warranty so 'fixed' for free then it's going on eBay..
Apparently, believe it or not, it's actually the stabilising gyro that causes the problem!!.. Awesome!..
Adios Sony..
Oct 23, 2008 | Sony DSC-T70 Digital Camera
It sounds like the Hyper board is begining to fail....Does the menu shake too?
May 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
73 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
