Question about Hyundai ImageQuest V995 19" CRT Monitor
ImageQuest V995 will not power on
Hi I am using a Gateway g6 300 win98 When ever I turn the computer off and back on this monitor will not power up. If I wait 2 weeks and plug it back up it works fine until I power off the computer. Anyone know how to fix this
  • 63 Answers
Sounds like the power ON circuitry for the unit has gone or is going out. When you state you unplug it and wait 2 weeks and plug it back in and works fine, this is direction of allowing the capacitive circuit to completely drain befor the unit is officially "Off". Something is causing the "on" circuits to hold the charge making the unit think it is still "on". By letting it sit and discharge, the circuit "resets" itself. The only real way to figure this out is to take it to a TV repair shop (not much different than a tv) and let them diagnose it. But it maybe worth the time to trouble to just replace it at this point.
Posted on Aug 27, 2007
I have got a hyundai monitor imagequest l50s , but the speakers won"t work
If the speakers are built in, check that the volume on the speakers via OSD is not turned all the way down or off. Many monitors that have speakers have an audio amplifier as the sound output from computers is very low and requires a powered speaker system in most cases. They are designed to operate head phones only now a days.
Mar 05, 2011 | Hyundai ImageQuest L50S 15" LCD Monitor
ImageQuest ImageQuest L17T 17" LCD Monitor: unit does not power up...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 18, 2010 | Hyundai ImageQuest L17T 17" LCD Monitor
Gateway screen not responding
Try Pushing together the body of monitor in middle top areaWhere the Word gateway is Imprinted ,Loose connection on ribbion probably,on mine ,but I think I got LUCKY here honestly,
Just try it before disassembly
Apr 11, 2009 | Gateway FPD2275W LCD Monitor
Gateway FHD2400 24inch monitor HELP PLEASE!
well it's not the computer going to sleep but the monitor is (sort of) because your computer is telling to. it has to do with the Power Options (title dependent on OS - this is what it's called in Vista)
Go to Control Panel>>Power Options - on the left hand column click Choose when to turn off the display - I'm guessing you are set to 15 or 20 minutes for the Turn off the display dropdown - change it to something longer to satisfy your needs (Never is an option).
If you're not running Vista write back - it's slightly different but similar path.
Mar 31, 2009 | Gateway FPD2275W LCD Monitor
Brightness adjustment
controling chip is gone, needs repair.
Nov 28, 2008 | Hyundai ImageQuest V995 19" CRT Monitor
Hyundai imagequest l90d+
the small board that handles all the buttons sounds as if it has gone bad you should be able to get a replacement on ebay
Sep 29, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Missing plug for monitor
It doesn't have a s-vid connector, that's the plug for the powersupply.
Jun 29, 2008 | Hyundai ImageQuest L50A 15.1" Flat Panel...
My Gateway FPD1760 Won't turn on.
Inverter or Inverter boards Blown.
Hope this helps.
Mike @ compurepair.
Feb 23, 2008 | Gateway FPD1760 17" LCD Monitor
My Monitor
Ok? first what you need to do is to hibernate your computer. You can do that by pressing the power button as long as you need for the computer to turn off. Then you turn your computer back on and press the power button ON THE MONITOR twice but you MUST do this really fast. Then what you need to do is to find a circuit breaker on the back of your computer. switch it to the off position then turn it back on. Then turn your computer on. This should fix your problem.
Dec 31, 2007 | Hyundai ImageQuest L70N 17" LCD Monitor
Blackness on monitor
Hi, A common problem to LCD displays. If you can somehow still see the desktop (...barely see the picture ...) then chances are that you have a backlight problem. This may either be the light itself which is a thin florescent lamp (CCF) or the inverter that powers it. Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Aug 30, 2007 | Hyundai ImageQuest ImageQuest Q15S...
Hyundai ImageQuest V995 19" CRT Monitor Logo
55 people viewed this question
Top Hyundai Computers & Internet Experts
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
