Question about Saws
Stihl ts 800
Cant get it started, it worked fine and now it just wont start
suzukiracing
  • 200 Answers
SOURCE: trying to start a stihl ts 400 disc cutter i
Try cleaning the plug and spray some starting fluid in the carb.Hope this helps and Thank You for asking!!!
Posted on Jul 19, 2010
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
snor38
  • 118 Answers
SOURCE: not getting spark when starting
fromsnor38@gmail.com HI GRYDERT your problem could be your on, off switch. This might sound funny, but switch the on off switch real fast several times, then see if you havee fire. If not check your spark plug. If you have a n
ew one try it. If that don't work check the connection at the plug to be sure it is makiong contact with the plug. If all this does't work you will have to go inside to the coil. They don't usually go ba d but it could. But first check to be sure it isn't grounded at the small wire from the switch. Good Luck.
Posted on Jul 01, 2011
  • 3 Answers
SOURCE: I have a stihl ts-410 cut off saw. it will start and idle but when i squeeze the throttle it dies. how do i adjust the carb?
if this machine ran ok before this problem,and no one has adjusted the carb,then i would check the crank seals.i have just had this problem.and it was the seal on the puller side,though i replaced both whilst i was at it.hope this helps my freind.
Posted on Jan 30, 2012
  • 2239 Answers
SOURCE: stihl ts 400 wont start
If there is good fuel in the tank and the plug gets wet with fuel, and there is a good spark stating the obvious it should go, if not there could be a mechanical issue, piston scored, rings worn etc,
Posted on Apr 17, 2012
Wont start-is getting fire&carb is rebuilt flywheel pinis ok
Check you fuel line configuration. More than one time they've come in with the fuel lines exactly backwards.
Jan 16, 2014 | Stihl Ignition Module Coil 050, 051, 076,...
Saw runs for awhile then shuts off and continues to run.
i always have to start the saw and then pull the trigger like every 5 seconds for about a minute then it works for me
Sep 18, 2013 | Stihl Concrete Cutoff Saw Carburetor Ts...
Stihl ts 400 wont start
Apr 16, 2012 | Saws
I have a stihl st400 disc cutter & I think the pull start needs cleaning, any advice?
compressed air works well. you really need a gun with a long skinny nozzle. for example
Jan 26, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl 410 wont start put new spark plug but no spark
Try a new coil.Hope this helps and Thank You for asking!!!
Jul 19, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
My stihl demo saw ran out of gas an i filled it back up with the proper mixture an now it wont start
Remove plug and clean/replace. also check in the tank for a filter on the end of the fuel line.
Ground the plug of the body of the saw and stry to start to see if you are getting a nice healty spark. If you tank ran dry then you may have contaminated your plug.
Jun 20, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
Hi there; my stihl ts 420 does not start easily
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Saws Logo
154 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
