Question about Casio Exilim Cameras
Keeps running thru slide show on casio exilim
5 Suggested Answers
memmory24k
  • 5 Answers
SOURCE: Casio Exilim EX-S600 not charging
Good day on you sir , you have same problem about my friend of mine,, Who have also Exillim S600..
Two Problem you may encounter for that 1st is you need to change battery for that and the 2nd if it not function after you change battery its mean that theres a problem to your current supply need to change repair it into the licence repair man , you may not be worry for the fees coz its only affordable and easy to repair you must avoid those who repair shop that needs you large amount of fees..
Posted on Jan 15, 2008
richard191
  • 691 Answers
SOURCE: my casio exilim ex s2 camera keeps showing
Hello
Thank you for using
FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 30, 2009
lock123
  • 6831 Answers
SOURCE: Casio Exilim EX-Z60: The camera shows "retry power on" and later
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 21, 2010
t00nz
  • 4738 Answers
SOURCE: I have a Casio Exilim
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (note 2GB or less standard SD cards. These are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Posted on Sep 18, 2011
How to unlock the casio exilim camera ex-z850
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 19, 2010 | Casio EXILIM ZOOM EX-Z850 Digital Camera
When I switched on the camera, the screen showed me "The card is locked" I assume it's talking about the memory card...but why???? My camera is a Casio Exilim EX-Z600
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 21, 2010 | Casio EXILIM ZOOM EX-Z600 Digital Camera
My casio camera shows "the card is locked" how do i get it unlocked
Remove the card and slide the little switch on the edge to unlock
Jun 02, 2010 | Casio Exilim EX-S600 Digital Camera
Casio ex-z80 shows card locked ?
Hello. If you look at the edge of your card you will see a small slide button ,make sure it's moved to unlock.
builderdale
Jan 28, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Kimly may -casio exilim the card is locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 05, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Casio exilim ex-80 always shows SD card as locked
the SD card should have a small switch on the upper left side it slides from lock to unlock if this doesnt work Look in the card slot - there may be a small bit of plastic sticking out over where the card's locking switch would fit when the card's inserted.
Oct 25, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
When i slide to take a pic it says that camara stabilizer is not available.
I have a Casio Exilim EX-V7 and I had the same Camera Stabilizer is not available problem, the firmware on my camera was 1.01 (hold down the menu key while sliding the cover open, keep holding until your firmware version displayed) From Casio.com, I downloaded the new firmware 1.03 (you need to register your serial number to do this (put in your serial number ONLY NUMBERS no letters from the bottom of the camera). Run the file you download to extract the bin file needed for the firmware. Connect the camera to your computer. When the folder opens put bin file into that location. MAKE SURE THE CAMERA BATTERY IS CHARGED. Hold down the shutter button (on top) at the same time press and hold the menu button then whil holding those two open the lens cover to power on the camera. It will prompt you on the screen to do the rest. It upgrades very quickly.
Mine still shows the Stabilizer error at startup however, it doesn't turn off and i can take pictures. Have fun and good luck.
Steve
Jul 02, 2009 | Casio Exilim EX-V7 Digital Camera
Casio EXILIM EX-Z110 (the card is locked)
If that doesn't work, try another card.
Jul 02, 2008 | Casio Exilim EX-Z110 Digital Camera
Casio Exilim EX-S770
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 14, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Cameras Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
