Question about U-Line Icemaker
Diagram ice maker parts bcm45a what freon does it use?Thanks
4 Suggested Answers
  • 5 Answers
SOURCE: i need the 3 rpm motor assy. for my marine ice maker model bcm45a
I think that's a .3 rpm (1/3 rpm)
Posted on May 15, 2008
bobicehouse
  • 1524 Answers
SOURCE: not sure of u-line ice maker part number for a BCM45A
Supco makes a generic replacement carried by most good Appliance Parts Stores.
Posted on May 04, 2009
  • 286 Answers
SOURCE: I have an old U-line ice maker. I can not find
The mechanical parts of those models is the same as a BI 95 or BI98. If your looking for the faceplate that would be part number 150. This includes the timer motor,gears,water switch, and hold switch. You can order this thru a parts distributor. Appliance Parts Depot or All Brand Parts should be able to help. If you want to replace the complete icemaker assemly that part number is 402
Posted on Jul 07, 2009
I have a kenmore model # 106.54582400 that has been moved and not plugged in for 3 months , i cleaned it all up like new and plugged it in and now its not cooling , its never been on its side , the motor...
The compressor freon got leaked or compressor got damaged while shifting.Get the compressor inspected.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Kenmore Refrigerators
My ice maker is not making ice. I have water to the valve located near the bottom back of the machine. It doesent appear to be getting through the valve and up to the ice maker. Also, when I moved the unit...
ur fridge might have run out of freon gas since the line that runs thru the valve was detached. the freon gas might have evaporated so there is a need to charge ur unit with new freon. this can be done by an ref and air conditioning technician.
Jul 08, 2011 | Refrigerators
No water to ice maker. I want to check the water solenoid to see if it is getting power. I don't have a diagram. is it a 120 volt solenoid? and when does it get the signal to open and allow water into the...
The water control valve gets its signal from the ice maker itself. Then begins the cycle of about six different functions until the ice ejector forks go to the position you see most (home) Then it tells the water control valve to open for about seven (7.5) seconds. You may test the true voltage from the female connection with a OHM meter set to AC voltage. Just have someone press the dispense water control. You can also check each sides coil windings for resistance or OHM's and they should be the same or very close to the same. Use care in the area of the coils and make sure the wires are not wet. One of the two wires for each side may be active even without pressing dispense or having ice maker call for water. Another thing I noticed is that you have two sets of water control valves. The problem is about as much with the Primary Water Control
Valve Part Numbers=> 12544002 and Secondary Water Control Valve => 12002193
as is the=> D7824706Q Ice Maker Module Whirlpool now owns Amana, Maytag, Jenn-Air and Samsung will not let me post their manuals to the public. I can answer your questions as need so If you need more answers or diagrams or photos Click Here=> Sea Breeze If you have any questions please ask, Thanks, Sea Breeze
Amana DRS2660BW Wiring Diagram
Amana DRS2660BW Ice Maker Parts Breakdown
Dec 14, 2010 | Amana DRS2660B Side by Side Refrigerator
Ice maker not working i think i need a new one
Well i think the Refrigerant(Freon) is finished in your ice maker that is why it is not making ice. Try to refill the freon and it will make ice for sure.
Regards, polysandy
Jul 01, 2010 | Refrigerators
My uline BCM45A ice maker is cold but does not make ice
This unit work on the thermostat. When the temperature gets between 10 - 15 degrees it will satisfy the control then turn the compressor off and icemaker will advance. If the control is set too cold then it will never satisfy the control. 1st make sure the thermostat is at the warmest setting. When the compressor cycles off look to see if the icemaker is advancing.If no then replace the control.
Sep 15, 2009 | U-Line Icemaker
Not sure of u-line ice maker part number for a BCM45A
Apr 04, 2009 | U-Line Icemaker
What freon 134A
The freon in most ice makers are R 410a at this time. You will be able to find the type of freon your model has listed most times on a data plate on the rear of the ice maker cabinet and on or near the compressor. R 134a is not always used in production ice machines because it does not freeze water as productive as
R 410a. The type oil in the compressor also will lead you more in the direction of the type of gas. Now If you need to replace the freon or compressor I can help you determine the exact type of freon gas was existing before the change, Let me know if this has answered your question. Thanks, Sea Breeze
Feb 06, 2009 | U-Line Icemaker
BCM45A
unplug and remove 4 screws from front of cover and see if the cam is not broken. every time it dumps ice this cam raises the bar to shut off ice making if the bin is full. may be it just slipped?
Sep 26, 2008 | U-Line Icemaker
U-Line Icemaker Logo
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
