Question about Poulan 25CC Gas BlowerVac
Fuel line installation for blower bmv200vs - Poulan 25CC Gas BlowerVac
  • 906 Answers
Follow the removal of the old one.
Posted on Jan 25, 2015
How to replace kill switch on a bmv200vs
Go to manualslib.com and put in the model number and it will show you a diagram of how to remove the switch. Hope this helps.
Sep 17, 2016 | Poulan Garden
How to change fuel line on craftsman blower
Before you start take a picture of where the old lines are connected to the carb and the primer bulb for future reference.
To replace the line pull the spark plug wire from the plug. Remove the old line from the tank and remove the fuel filter from the line. Take new larger line and cut it on a 45 degree angle/or trim as necessary so you can grip it from inside the tank and pull it into the tank. Perform the same operation on the smaller line as well. Be sure to leave enough line for the fuel filter to reach the bottom of the tank. Install the fuel filter. The other small line is a vent line and only needs to come inside the tank not go to the bottom in the fuel.
Good luck.
Jun 07, 2014 | Craftsman 4 Cycle Blower/Vac
Poulan blower fuel lines
I would guess the fuel line you installed is kinked somewhere.
Jan 12, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Blower does not get any fuel. Installed new carb checked and removed fuel filter and air vent and still wont start. why is it not getting any fuel? what have I missed?
One question: Is the unit equipped with a primer? If so what does priming do? If it wont prime do the following:
Check your fuel lines to verify they arent collapsed or blocked. Also replace the fuel clunk in the gas tank. Check fuel cap vent for blockage too. Finally, make sure the fuel lines havent been crossed. Good luck and be careful!
Oct 01, 2013 | Echo Gas Blower 135 MPH390 CFM Blower...
Fuel lines poulan bvm200vs gas blower
You need to split the entire unit to get to the fuel tank. Remove carb, remove exhaust, and remove right side of plastic enclosure. Check the cylinder to make sure it is tight, these units are notorious for the cylinder coming loose. Remove the tank and install your new fuel lines, leave them long then trim to fit once reassembled. Check to be sure the isolator mounts and starter rope ferrule are in place when reassembling
Jul 17, 2012 | Poulan Pro Gas BlowerVacuum ()
Both my Echo line trimmer and Stihl hand held blower. No fuel in the bulb on both, I suspect bad fuel. If so, how do I fix?
Check INSIDE the fuel tank. It is possible the fuel line inside the tank has deteriorated and the filter broke off. That would cause fuel line to FLOAT in the tank instead of lie on the bottom. This could easily be the cause of no fuel in primer/purge bulb. You probably need to:
Install new fuel filter..........Install new fuel Lines.......Install new primer bulb........Clean carburetor.
So in some respects, you are probably correct....no fuel filter equals bad fuel entering carb (but if none in bulb, doubtful much fuel (dried up maybe ) in carb.
Sep 06, 2011 | Husqvarna 28cc Gas Line Trimmer
Need to replace both fuel lines on My BVM200 LE leaf blower, 1 large and 1 small fuel line, can You tell what size they are??
On your blower, it looks like the small line supplies fuel to the carburator which will be connected to the fuel filter in the tank, and the large line looks like the fuel return line.
http://www.ereplacementparts.com/poulan-type-gas-blower-parts-c-16962_31724_131359.html
Jul 19, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
I bought this blower last week,i tilt it alittle and heard a rattle sound and now it wont start
Check the fuel filter in the tank and make sure the fuel line is connected to it. The carburetor may have inhaled some debris and/or small chunks of broken fuel line and need to be opened up and cleaned also. At this point, you would probably need to install a new fuel filter also.
Jan 15, 2011 | Weedeater 25cc Gas Blower ()
How do I replace the fuel filter and the two fuel hoses on my Homelite leaf blower? The fuel filter is inside the fuel tank.
Take your Model number of your machine and the model, type, and code of your motor to your local small engine repair shop and have them get you your replacement filter and also pick up new gas line. When you replace your fuel lines do one at a time. All you have to do is pull a fuel line off, cut new line to length and re install. As to the filter in the tank, I usually take a coat hanger and fish it up to the top and then use needle nose pliers to grip it. Then just pull off the old filter and install new one.
good luck
Aug 31, 2009 | Homelite 'Yard Broom' Leaf Blower
WEED EATER BLOWER BV 1800 FUEL FILER REMOVAL AND REPLACEMENT
According to the Weed Eater Instriction Manual, page 8:
REPLACE FUEL FILTER: To replace fuel filter, drain unit by
running in dry of fuel, then remove the fuel cap/retainer assembly
from the tank. Pull filter from tank and remove it from the the
fuel line. Install a new fuel filter on fuel line; reinstall parts.
Tip: Sears outlets have a big selection of tune-up items for
blowers, etc. Try them for needed parts.
Mar 21, 2009 | Garden
Poulan 25CC Gas BlowerVac Logo
238 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
