Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Code e220 error - Canon imageRUNNER 3300 All-In-One Laser Printer
    New Friend:
  • 3 Answers
An ink cartridge is not installed properly. Open the printer's cover, make sure the ink cartridge is installed properly , and close the cover.
Posted on Jul 10, 2013
Canon ir400 error code e100, e220 solution
Hi . 2 different error ... it seem like there is a problem in the power board
Feb 13, 2018 | Canon Office Equipment & Supplies
E220 error drying
i came across a hotpoint had error E220
it turned out to be the pump housing was cracked and leeking water back to the motor windings and they had gone short
and the brushes on the drum motor were worn away
replacing the pump rear section and the brushes
and resetting the error {hold in power btn power up at the mains}
cure it
i then had to come back too it and replace a faulty 1Amp triac and its driver transistor on the machines micro/control board
because although it worked aok the triac already had been damaged
and the increase in duty etc of the new pump
tipped it over the edge
replacing these two parts cure it for good
that was over a year ago and no new problems
Jun 07, 2014 | Hotpoint Aquarius WMA52 Front Load Washer
How to solve e220 and e218
Both of those errors revolve around the laminator.
E220 is Lam2 Tag Error
E218 is Lam 2 Head Lift Error
I would recommend replacing the laminator.
Sep 19, 2013 | Office Equipment & Supplies
Canon ir600 error code E220
sira canon 600 mechan E220 has cmming turn of the power has coming solve the problam how to slove the problam slove it
Jul 17, 2012 | Canon ImageRunner IR600 Copier
Machine canon ir 400s error E051
hi sir my xerox machine IR 400 the error code e220
May 12, 2012 | Canon imageRUNNER 400S Copier
Canon ir 400 error code 051
I m E220 Error how to clear the error of Ir 400
Jul 29, 2011 | Canon imageRUNNER 400S Copier
E220 error
it show exposure lamp blown or bad contact, open upper cover and check for possible connection for the lamp for replace if possible.
Apr 12, 2010 | Xerox Phaser 7760/YDX Laser Printer
Error code e220 for canon gp 405
That is a scan lamp error on all Canons that I know of. Check continuity on the lamp. Then check the in line fuse. It could also have a shorted scan cable.
Nov 09, 2009 | Canon GP-200 All-In-One Printer
Error code definition
All I can offer is From Canon:
Problem :
The machine displays an error code of E220. The code only displays when copies are made off the glass. Originals copied using the Document Feeder do not cause the code to occur.
Solution :
Unplug the copier and remove the Copyboard glass. Move the scanner manually and check to see if the Scanner Home Position Sensor Flag is coming into contact with the Inverter Pcb, or any of the wiring. Contact with the flag may be causing a short during Scanner movement when copying from the glass.
Problem :
Error Code E220-0001 occurs after replacing the Lamp, Inverter PCB and the Reader Controller.
Solution :
Check and verify the 24V supply to the Reader Controller from the Main Power Supply (Switching Regulator) is present. It is possible that one of the loads on the DC-Controller can take down the 24 volts. Remove the 24volt loads off the DC-Controller and connect the connectors one by one to locate the short or defective load.
Apr 14, 2009 | Canon imageRUNNER 2200
Canon np1530 copier e220 error message problem, how can solve this problem?
E220 is a scanner error. means:
the exposure lamp is burnt.
try copying with the top cover open, if the lamp does npt work, exchange it.
Good Luck.
Mar 12, 2009 | Office Equipment & Supplies
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
old marine
old marine
