Samsung HL-S5686W 56
TV reads, "Check # 1 Fan." Where is the # 1 Fan located and how do I check it?
    Champion:
  • 247 Answers
Check if its running n if its dusty,by turning on the tv it has to spin in tandem with the lamp lighting and spin for a while when the lamp is off
Posted on Jul 11, 2013
SOURCE: Samsung HL-S5679W Check no. 3 fan message
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Posted on Mar 24, 2009
falspet
  • 438 Answers
SOURCE: message on my tv reads check fan 1..
check fan 1 means the fan is not cooling, check to variety the fan is indeed working, the unit is shutting down due to over temp. if there is a filter, clean it
Posted on Jan 31, 2010
  • 55 Answers
SOURCE: Samsung HL-S5686W 56 in. HDTV SHUTS OF EVERY 1O-15
if you're getting the 3 indicator lights coming on, more than likely you'll need to replace your tv lamp. open the panel and have a look in there. lamp probably blown.
Posted on Apr 14, 2010
cadillac02
  • 318 Answers
SOURCE: i'd like to brighten up the picture kinda dim
Turn up contrast to 95 and turn down brightness accordingly. If it is oddly dim, you may have a problem with the backlight.
Posted on Jan 28, 2011
Mas Baz
  • 177 Answers
SOURCE: Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Posted on Mar 30, 2011
Testimonial: "THANKS "
How do you replace a bulb in samsung projection tv hls5668wx
There is a video of the procedure here: http://www.samsung.com/us/support/owners/product/HL-S5686W . Make sure to get the exact matching lamp code number and type. This is listed on the right side of the TV and on the lamp case.
Then turn off the TV and let it cool for at least 30 minutes. Make sure not to touch the glass with your bare hands (particularly with the new lamp). Remove the single screw from the lamp cover and then remove the lamp cover. Remove the lamp cover duct by holding the locker and pulling it towards you. Next remove the screw holding the lamp in the housing. Separate the lamp from the housing by holding the handle and pulling it towards you. Reverse the process with the new lamp. Make sure the lamp cover is seated properly and the screw tightened to get the TV to come on.
I hope this helps.
Jan 30, 2011 | Samsung HL-S5686W 56" HDTV
I'd like to brighten up the picture kinda dim samsung hl-s5686w what can i do?
Jan 28, 2011 | Samsung HL-S5686W 56" HDTV
Hi , 2 weeks ago i noticed some dead pixels showing up on my screen (white dots) since then i'm up to 10 dead pixels. What can i do? I heard it might be the dlp projector that has to be replaced...
White pixels are STUCK pixels, not dead. Read the warranty beacuse at a certain number of stuck/dead pixels, the tv is repaired for free by the seller if is in warranty period.
Nov 02, 2010 | Samsung HL-S5686W 56" HDTV
No power
Check the color wheel, take out lamp and look at color wheel with flashlight see if moving, make sure you tape down or up lamp door switch. If color wheel turns or not? Have same tv my probelm was the color wheel. cost around $70 easy to install>>>>
May 31, 2010 | Samsung HL-S5686W 56" HDTV
My samsung dlp hl-s5686w turns for a minute video disappears audio continues and three lights flash the standby/temp,timer,lamp. all at the same time.
I'm having the same problem. Tried several things from dusting the inside with an air blower, removing the bulb and putting it back in, making sure the side panel is installed correctly and none of this has kept it from shutting off. Samsung's site says the three lights flashing means replace the bulb but I'm not buying it. My picture looks perfect....jsut that the TV keeps turning off. It all seems like a heating problem but my fans are still working. I'm scratching my head thinking what to try before forking out $150 for a new bulb.
Apr 30, 2010 | Samsung HL-S5686W 56" HDTV
Samsung HL-S5686W 56 in. HDTV SHUTS OF EVERY 1O-15 MINUTES SOLUTION?
Apr 14, 2010 | Samsung HL-S5686W 56" HDTV
I have a hl-s5686w samsung dlp tv, the problem is that it have dead points or dead pixels (a lot of white points)on the screen,if somebody know what is the solution to fix this problem. please let me...
ok well it seems to be an issue either with yoru DMD board or your Digital Video board, go to the menu and if those white spots are also showed on the menu, the issue is with your DMD board, but if they're not showing, the issue would be with your Digital Video board
Jul 23, 2009 | Samsung HL-S5686W 56" HDTV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
