Question about GPS
Garmin nuvi 255 lm
Deleting
  • 35 Answers
SOURCE: garmin nuvi 255 won't turn on
Have you tried doing a hard reset,try using the reset button on the bottom of the gps under the serial label.Or try holding the turn off button for about 10 seconds,good luck.
Posted on Sep 05, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Garmin Nuvi 255 died. How do I reset it?
Hello there:
If you unplug the unit and remove the battery
i would check the fuse inside the unit to be sure that it is ok if it is than
leave it unplugged and the batttery out for 30 min and if there is a reset button on this after the battery is removed hold in the reset in for 2 minutes then after the 30 min replace the battery and plug in the unit and try it again his should be enough time for the internal reset to reset it'self than just replace the battery and if this still oes not help remove the battery again and leave it sit for 1 hour to let the internal reset device reset it'self ok and you should be good to go
Hope this is very helpful
Best regards Michael
Posted on Dec 10, 2009
taran_2005
  • 10515 Answers
SOURCE: how to change language on a 255?
On the very first screen after the GPS boots there will be an icon of a wrench at the bottom right of the screen. Press that Icon and scroll through the menu and you will find a language setting.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 11, 2009
Testimonial: "Thank you! Merry Christmas!"
HarryHarley
  • 343 Answers
SOURCE: how do we update our garmin nuvi 255
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You can get that FREE at Garmin here:
To download the latest unit software visit Garmin website: www.garmin.com/webupdater
First you have to set up an account at Garmin using the serial number on your GPS. Once you do that you can download firmware update for free.
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
By the way, the correct Garmin approved power OR download cables are a must!!
Does this help? Let us know. Thanks.
Posted on Feb 06, 2010
vanherringto
  • 1738 Answers
SOURCE: My Garmin Nuvi 255 doesn't appear to have a reset
Owner's Manual Rev. D, Sep, 2009 arrowblack1.gif(Click here) Download
See page 42 of the manual to reset your device.
" If your nuvi doesn't have a reset button, slide the power key to the on/off position and hold it for 8 seconds."
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
Posted on Feb 07, 2010
DELETING MAPS ON NUVI 40 LM
Plug your GPS into your PC, it will mount as a hard drive. You can then open the folders and delete content. As easier solution is to put a 8gb micro SD card in the SD card slot. Garmin Express will allow you to put additional maps on the SD card.
Mar 22, 2017 | Garmin Nuvi 40Lm - Gps Receiver
Tip
Download Nuvi 255 Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 255 or 255W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
on Apr 16, 2010 | Garmin NUVI 255 PERSONAL GPS Device
Tip
I hope that helps.
on Apr 16, 2010 | Garmin Nuvi 255 Car GPS Receiver
Garmin nuvi 50 LM froze
Press the small reset button for 5 seconds then power the unit off and then back on again. This should clear the problem.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 12, 2012 | Garmin Nuvi 50 LM
Garmin nuvi 255
Hook your Garmin into your pc -using the USB cord provided with the kit- run the disk -then go to GARMIN dot com and look for maps for your unit. There is a charge. 1687c58.jpg
May 02, 2010 | Garmin nuvi 250W GPS Receiver
Tip
I hope that helps.
on Apr 16, 2010 | Garmin Nuvi 255 GPS Receiver
Tip
Download Nuvi 255W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
I hope that helps.
_____________________
Garmin Nuvi 255W Hard Reset Here.
Garmin Nuvi 255W Favorites Backup here.
Garmin 255W WebUpdater here.
on Apr 16, 2010 | Garmin nuvi 255W GPS Receiver
I downloaded a new version of the Garmin Europe maps (2011.10 from 2010.10) but it is too large a document for my sat nav a nuvi 255. I have now only got central and eastern europe, which I want , but I...
Copy the new maps onto the SD card be sure that the card has enough space on it. ( you might need a SD Card reader ) copy the old maps onto your PC before deleting the SD card, copy all the data into the root folder of your sat nav. hope this helps
Apr 27, 2010 | Garmin Nuvi 255 GPS Receiver
Garmin Nuvi 255 2008 screen not respnond to touch
There should be a reset on it and it should bring it back.
Dec 25, 2009 | Garmin Nuvi 255 GPS Receiver
Replace battery garmin 255
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Apr 04, 2009 | Garmin Nuvi 255 GPS Receiver
GPS Logo
20 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
