Question about Ovens
O keefe merritt gas stove model number 425-15
The oven won't stay lit but the broiler will, why is that?
  • 10 Answers
SOURCE: burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Posted on Nov 19, 2007
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
  • 106 Answers
SOURCE: I have an 1950s' O'Keefe & Merritt Gas Stove
if the springs are not broken , the hinges are bent down ( droping the door for 60 yrs). Its tricky to bend back the hinges back. Springs and parts are no longer avaliable but you may be able to match someting close for a spring if you have the old one.
Posted on Oct 30, 2009
SOURCE: I have a caloric heritage series gas stove in
We replaced the igniter which I bought from the appliance repair service. We now have a working oven.
Thankyou for responding to my email.
Cheryli
Posted on Jan 04, 2010
SOURCE: where are the fuses for the oven broiler on model # 9752834A
naps is asking oven element is not working or starting dosen't light up
Posted on Feb 09, 2010
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
My tappan oven won't work. stove and broiler work fine. ignighter glows but it seems like there is no gas.
I would check with your manufacturer and see if a professional can diagnose the regulator and even the gas valve itself.
Jul 17, 2012 | Tappan Ovens
I have a Whirlpool super capacity 465 gas oven that won't stay lit. It often lights up the first time just fine but then it turns off which is normal but when it tries to relight itself the ignitor...
That sound to me like yall have some carbon buildup on the igniter. On this stove the igniter does 2 jobs. It lights the burner and verifies back to the control that Houston we has ignition. If junk is built up on that ignitor then she won't be sending verification of ignition back to the control. That white residue needs to be removed. NOTE: I don't have your model number I am going by what you describe that this stove is a Direct spark ignition model. If you have a normal ignitor it probably is weak and not drawing 3.5 amps to open the valve. Post a model number (bottom drawer frame)
More Here
Sep 08, 2011 | Ovens
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 | Ovens
I have a roper free standing stove. Everything seems to work except the oven. When I turn the thermostat to broiler it works but doesn't when I turn to oven
next time send the model number and say if it's gas or electric?if it's gas you have a bad bake ignitor,if it's electric you have a bad bake element
Apr 22, 2011 | Ovens
Oven and broiler will not come on.
go to www.repairclinic.com enter model number and look for the igniter it seems to me you need to change this part. Note it is very fragile.
May 02, 2009 | Ovens
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at oldvic@erols.com
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
