Question about Carrier 38CKC036 Air Conditioner
Carrier Infinity DC motor drive problems
I have a new Carrier super high effeciency furnace, AC and PLC digital thermostat. New under warrenty. The CD motor drive starts cycling the motor 150 to 300 rpm in 2 to 3 second intervals until I turn off power and reset system. It will run anywhere from 1 hors to 3 months with no problems and then start doiong this again. Help[? EVAP CD6AXCo48021ABAA Furnace 58MVP120 AC cond 38TZA042331 Infinity digital thermostat software version CESR131339-05 Thanks.
    Novelist:
  • 75 Answers
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
Posted on Aug 27, 2007
SOURCE:
Zone control not working
These are both power open and closed. Yellow and green should be constant on the leds. C&D is your 24 volts for the controls. If you got power going in but nothing coming out of the board it is bad. If you got 24 going to the damper but damper not responding obviously it's bad. Usually communication is DC voltage, likely 12 or 13 DC at A&B. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 13, 2017 | Heating & Cooling
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
We had a new Carrier Weathermaker Infinity Gas Furnace installed in our home on 9-21-99.The Carrier people said the furnace was in good condition this past October.But prior to that as of April 2010 the...
Your Carrier guys more than likely are Carrier dealers. I would get a second opinion. Most qualified HVAC techs can work on any and all brands. It doesn't need to be a Carrier dealer to work on a Carrier. AND, if they replaced the control board and didn't test the heat, that's a fault on their part. Anytime we change a board or even a thermostat, we check ALL modes and functions. SECOND OPINION!!!
Mar 10, 2017 | Heating & Cooling
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Nov 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrie Furnance will not power up. When I turn my thermostate to heat or off it goes blank. It works on central air. I checked the breaker and it is on. I made sure the switch is on at the furnace. There...
if under warrenty DONT MESS WITH IT call hvac co out WORST THING IS TO GO TO A CALL were harry home owner has pulled stuff appart n got wires crossed makes the techs job un real ive walked on basket case calls like this i dont build em just fix em as for waTs up if u got fan on with ac and nothing on the heat and stat blanks out im leaning toward either a stat issue or a fnky board......i
Oct 05, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Infinity Control Programming Issue
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
Feb 27, 2009 | Carrier Heating & Cooling
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Carrier 38CKC036 Air Conditioner Logo
550 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
