Question about Kitchen Ranges
Whirlpool gas range model no. SF 315 pegq 6 oven will not light
The oven will not light on this gas range
SOURCE: Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Posted on Nov 24, 2008
  • 341 Answers
SOURCE: frigidaire gas range ES100 oven will not light
I had a similar problem with my Kenmore and it was the Igniter. Cost me about $85.00 for a new one. Sometime on the back of the range there is a little pocket where sometimes a schematic is there and ( I don't know about your Frigidaire) but with my Kenmore it gave troubleshooting info that was very helpful in determining the problem.
Posted on Jul 18, 2009
erpaalai
  • 999 Answers
SOURCE: Whirlpool Gas Range Oven will not start (gas flows, but no spark)
The ignitor does 2 things. It creates the spark for ignition and it signals the control the burner is lit(flame sensor). If the ignitor and wire are new the spark module is bad. If all spark components have been replaced then I would be searching for a poor ground wire. Are you by any chance using a GFCI circuit? Not recommended and if it worked on this type of circuit you were just plain lucky.
Eric
Posted on Nov 01, 2009
  • 77 Answers
SOURCE: Kenmore GAS Range, model 970-334422,
it is very likely that the display may have gone bad. but before you buy a new one does it have any thing on it at all
Posted on Aug 19, 2010
SOURCE: How do you change the light bulb inside the oven
Just unscrew the glass cover and change out the bulb.
Posted on Oct 10, 2010
Have a whirlpool accubake that needs to be converted to propane Model SF36zlxsy
Whirlpool 9755428 Conversion Kit (lp Gas ...
www.appliancepartspros.com > ... > Range > Whirlpool Range Parts
$18.90
Spud kit for lp gas conversion., 9755428 / AP3176464 made by Whirlpool. ... I needthe LP Conversion Kit (Orifices) for the model WFG320MOBS. What is the ...
[PDF]GAS RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesIf you should experience a problem not covered in TROUBLESHOOTING, ... You willneed your model and serial number located on the oven frame behind the ...... TheACCUBAKE® system electronically regulates the oven heat ..... Range convertedimproperly. If propane gas is being used, contact a service technician or.
Dec 20, 2015 | Whirlpool Kitchen Ranges
Whirlpool oven wont light
The igniter has to heat the thermocouple to turn on the gas valve so if the igniter is glowing brightly either (or both) of those components could be at fault.
Mar 11, 2014 | Whirlpool Kitchen Ranges
GAS OVEN KNOB STUCK
The valve is 'seized'. Grease gets into them and over time turns acidic corroding the valve from the inside out. Replace the valve. Any appliance parts seller can get it for you. Turn off the gas before starting repairs!
Apr 30, 2017 | Whirlpool SF325 Gas Kitchen Range
Whirlpool gas range error code f2
Hi sauerteig_j,
Whirlpool F2 error code indicates that oven temperature is too high. And to fix this problem:
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just have your model # ready when you call.
Hope this helps.
Thank you for using FixYa.
Feb 08, 2011 | Whirlpool GS475LEKS Gas Kitchen Range
Whirlpool gas range model # GS475LEMS0; Oven light won't come on
If you are sure the bulb you purchased is ok, then I would check the door switch. It is #27 in the attached breakdown, and the part number is: 3196262. Hope this helps. 250
Nov 16, 2009 | Ovens
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
Nov 03, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
I have a whirlpool gas oven model # SF395LEEBO
Oven temperature sensor opened Replace oven temperature sensor
Jan 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
