Indesit wixe 127 flashed code f-12 then display went off and now won't stop filling with water
It had error f-20 then heard a bang then it flashed f-12 now nothing works and just fills with water
SOURCE: My indesit wixe 127, wont
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
Posted on May 17, 2009
barkencoa
  • 3463 Answers
SOURCE: Indesit wise 127 x F-10 error on the screen
F10 means no cold fill.
Check cold water supply, and check drain out let hose is not kinked.
Please rate my soilution.
Thanks.
Posted on May 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: Manual for Indesit WIXE 127
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Posted on Sep 16, 2010
taran_2005
  • 10515 Answers
SOURCE: Indesit WIXE 127 The machine is
Demo Mode
If the machine is on Demo mode 'D on' will be displayed and the machine will NOT function.
To reset the machine for normal use:ยท
Turn the power off at the wall.
Push in and hold down the Start/Stop and the Start/Reset
buttons, while still holding down, turn the machine on at the
wall.
'D off' will be displayed and the machine will function
normally.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 20, 2010
  • 1751 Answers
SOURCE: Code F-05 showing on INDESIT
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Posted on Jan 03, 2011
My machine starts and then flashes F12 and stops working what's wrong please?
Deborah,
if your machine is a Hotpoint/Indesit the F-12 error code is a communication error between the main pcb and the display pcb. No simple fix im afraid, a new main pcb is required.
you will need to contact the manufacturer.
Aug 19, 2016 | Whirlpool Washing Machines
Indesit wixe 127 door error
Most likely have to change the door lock and latch assembly.
Sep 04, 2012 | Washing Machines
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Jan 03, 2011 | Washing Machines
Model WIXE 127 instruction manual I have lost the one provided with new machine
Go to -
WWW.INDESIT.CO.UK
In the menu on the left, click on--- Indesit user manuals.
Then in the search box, enter your model number, and download the instructions.
Please rate my solution to your query.
Thankyou.
Jan 15, 2010 | Indesit Washing Machines
Fabric conditioner not going
Check the solenoid belongs to that tray.It may struck.
Jul 05, 2009 | Indesit WA 125 Front Load Washer
Thanks.
May 20, 2009 | Select Brands Washing Machines
CLICK HERE
Apr 07, 2009 | Washing Machines
My indesit wixe 127, wont drain and is stuck on error code f05. what doi do?
Aug 11, 2008 | Indesit Washing Machines
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
