Question about Canon CLC 1180 Copier
Service manual my canon clc 1180 have eror E020 an sub eror is 00A3
    Top Expert:
  • Canon Master
  • 11,573 Answers
Posted on Aug 09, 2016
Code error E 020, 0173
Posted on Aug 15, 2013
3 Suggested Answers
  • 67 Answers
SOURCE: E020-00A3
your back up data is currupt, you need to change your p-sens-p value check your door spect for all default value. after that clean your sensors that is found below the black developing assy. take machine off unplug from outlet replug turn machine on DO A GRADUATION ADJUST that should solve the problem / if not unplug the the same sensors , then repeat the first prod.
Posted on Jan 10, 2009
  • 64 Answers
SOURCE: i have a clc 1180 machine gives error code E020
black toner drum
Posted on Jan 16, 2010
E020 00a3
needs fuser assembly. probably bad thermistor.
Nov 14, 2012 | Canon CLC 1140 Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
E020-00A3
Dec 24, 2008 | Canon CLC 1180 Copier
I have a problem with my clc 1180 machine.. i have an error code E020 subcode 00A3... i changed the black sensor ,the developper assymbly, the dc controll board,drum..... still i have same error....can you...
ok so this is a code for the atr sensor.. you said you changed it is that the one right above the black dev that has the connector that plugs up under the control panel. if it wasnt take that one out and clean it... you can also check under serv mode copier display dens and see what iy says under window for each color they should be around 100 you may want to try to clear R-CON but then you need to put all adjs back to door specs
E020 sub-error 0273
go into service mode function or adjust and put in all the door spects take machine off then on do a graduation adjust
Sep 05, 2008 | Canon CLC 1180 Copier
CLC 1180 with error E020 with sub 0124
Did you change the Magenta stater/ developer? A E020 code is saying that the toner desity is low. Try replasing the developer and run the ATDC for Megenta and see if that helps. You may have a problem with the developing ass'y it self. You may be able to take another colors dev. ass'y with the hopper open and see if the code goes away. The sub code 0124 means that it is the Magenta dev. ass'y
Jan 29, 2008 | Canon CLC 1150 Color Copier
Canon CLC 1180 Copier Logo
207 people viewed this question
old marine
old marine
