Question about Coffee Makers & Espresso Machines
Aeroccino stuck on blue button - Coffee Makers & Espresso Machines
Aeroccino milk frother is stuck in blue. How do I
The best way for that is to visit the company where you have bought your frother or call the customer service hotline.
Amazon com Kitchen Ace Can Opener Stainless Steel with Smooth Edge...
Sep 28, 2014 | Coffee Makers & Espresso Machines
Nespresso Aeroccino 3 does not heat and froth
I got mine today exact same thing happens... only blue does not warm AT ALL
Aug 26, 2012 | Coffee Makers & Espresso Machines
Aeroccino frother won't turn back on after we get some froth and still more milk in container.. takes a long time to be able to activate again.. using Almond milk could be the problem any suggeest
My Nespresso Aeroccino often would not heat or froth multiple times after one use. I called Nespresso, they have excellent customer service, and was told to rise the inside (careful not to get the outside button or electric elements wet) of the Aeroccino with cold water a few times and to retry. Works like a charm!
The customer service is the best I have encountered in a long while, give them a call, it will make your day they are so pleasant and helpful!
Feb 18, 2012 | Nespresso Aeroccino Automatic Milk Frother
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
How do I make cold froth on my aeroccino for my lattes?
Press the and hold the button for 5sec or longer until the light turns blue. That will get you cold froth.
Jun 27, 2010 | Nespresso Aeroccino Automatic Milk Frother
How do I get the blue button to come on?
Press the button and hold it for 5 sec or longer until the button turns blue.
How to get cold froth
Press and hold the button for 5secs or longer untill the light turns blue.
May 29, 2010 | Nespresso Aeroccino Automatic Milk Frother
My Nespresso milk frother did not come with instructions. Is there some way to froth but not heat the milk?
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Jan 25, 2010 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino does not heat
Try descaling, if the element is covered with scale it wont produce enough heat and pressure.
The machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Oct 06, 2008 | Nespresso Aeroccino Automatic Milk Frother
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
