Question about Garden
Rzt 50 17ba5a7p710 wire harness rewire
Had a short occur on mower and burnt wire bad from switch to selonoid, tried to wire with color codes but found several to be of same color, now can`t get mower to crank, HELP, lol, need a wire diagram to figure witch goes where
SOURCE: Mower tripped outlet breaker - wiring schematic available?
I had a MM875 go out after some months' service -- it actually went out with a bit of a bang. The problem was a shorted circuit; the weather was hot and the "solid state switch" on top of the motor shorted out. This part wasn't a switch but a bridge rectifier. The original part was specified a bit close to its actual working limits so I bought another (from Radio Shack, no less) that was higher rating -- something like 30 amps at 200 or 400 volts. ITs worked for years.
If it is a bridge then it will have two terminals labelled '~' and one each with the '+' and '-'. The plus and minus go to the motor (keep those connections the same as the original) and the others go to the supply wires.
Posted on Jul 15, 2008
  • 5 Answers
SOURCE: Wiring problem
I'm sure you can find parts many places online. I got mine from www.ToolPartsDirect.com. If you type in the model number, you can see a complete parts diagram. The switch is part 9 on the diagram; about 15 bucks. When I was mowing, I smelled a burning electric parts type of smell. The motor brushes wore down from use. Now my wife can't tell me I don't mow enough!
Posted on Jul 24, 2008
  • 4 Answers
SOURCE: 1999 Grand Cherokee Radio Wiring Harness Diagram/Color Codes
Go to www.installdr.com and search through the diagrams in there, the site is easy to use, all you need is acrobat reader installed on your computer to use the site, it has a full explanation on every wire color and what it is
Posted on Aug 30, 2008
  • 290 Answers
SOURCE: need wiring diagram for radio on 96 mercury sable
http://www.the12volt.com/installbay/stereodetail/1500.html
Posted on Mar 23, 2009
etirbynnor
  • 655 Answers
SOURCE: Need wiring harness color coded diagram for pioneer dehp6800mp.
Hello randscates,
Here's a link to the manual. The wiring color code for the supplied harness is on page 78. The diagram is rotated 90 degrees clockwise. I recommend that you download the PDF and print out the page you need.
Hope this helps.
Posted on May 16, 2009
My RZT 50 turns blades on when levers are pulled back instead of shutting of and shuts off when in forward position ? could it be a switch is bad if yes what switch?
Sounds like someone has been working on the wiring, probably trying to bypass the reverse cut out switches . If you follow your steer control lever down under the plastic console covers there will be a switch, one on each steer lever by where it hinges. I don't think the switch is bad because it would not work at all if it was.It is like a door bell switch, when you pull back on the steer control lever it pushes it in and disconects the circuit to the PTO switch and the blades quit until you push them forwards and lets the curent through again. Also check the push pull PTO switch .Every safety switch on the tractor will meet at that switch and plug into it, . That model cub RZT50 has to have the worst switches ever made, but they are available and cheap on ebay. Plunger Switch 430362 430 362 for Cub Cadet Troy Bilt MTD 700 Series 725... PTO Switch MTD Cub Cadet Mowers GT RZT LT Force Mowers 925 04175
Apr 25, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
My pto is on all the time on my Toro zero turn. Blades are engaged when I start the engine even though the switch is in the off position? What would cause this?
Haven't had your particular problem, but my my blades would not turn when I pulled the PTO control knob. Turned out to be a bad PTO switch. Mechanic replaced the switch and it worked fine thereafter.
Dec 26, 2014 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
How do I check the safety swiches on my 26jmini rider?
I take it it won't turn over or start (did you check for blown fuse first)Safety or interlock switches are a pain ,but not impossible. I use an ohm meter to check.
there is 2 to 4 wires to each switch and usually 3 switches on a mower SEAT,BRAKE,PTO or BLADE engage.
the two white wires that run to the safety switches are the mostly color used wires that complete the starter starting circut .
unplug connecter from switch and use a piece of short wire (paper clip works nice) to connect or short the white wires together do this to all safety switches and try to start.
check for broken wires and pay special attention to start selonoid witch is part of circut.
Oct 06, 2014 | Garden
My engine will not turn over. Replace the battery still will not turn over
It may be the starter,switch or starter selonoid...to check the starter in place, try this, turn the switch to the run position then locate the starter wire connector on the starter and using a jumper wire or screw driver place the wire or screw driver on the connector and to ground" the engine block or any metal " if the starter turns and runs..it most likely is you selonoid..to check that..follow the red wire from your battery. it connects to the selonoid that gives power to the starter from the switch.It has two theaded bolt post with nuts one from the battery and one to the starter,,,now use the same wire jumper or screw driver with the switch to the start position " may need some one to turn to start position if using a screw driver " then cross it..if the starter runs...it is a bad selonoid..if nothing you switch is bad..both are fairly easy fixes..good luck
Sep 20, 2014 | Troy Garden
How to turn off reverse stop mowing switches on a 2013 rzt 42 cub cadet ?
unhooking your battery will clear codes might work for this to as long as your tractor isint in reverse
Sep 02, 2014 | Cub Cadet Garden
Fuses keep blowing in mower,put aluminum foil around the fuse now it wont start back,what happend?
You had a short..you ether melted the wire or burned up the starter or switch...need to try putting direct voltage to the starter and to ground and see if it turns.if not bad".try putting a screw driver or jumper across the selonoid poles if it clicks and turns the starter the wire to the starter is ok if not sure is burnt or melted .Check for burnt switch and or wires..never do the aluminum truck..will do damage or cause a fire..good luck
Aug 09, 2013 | Briggs & Stratton Garden
Pto blows the fuse everytime i engage it on my rzt 50 cub cadet mower.
Wire harness for the PTO on the RZT's is designed dangerously near the drive pulley. After time, the harness drops and comes in contact with the pulley which grinds through the coating and shorts out the circuit. Repair (tape up) the wiring, relocate the the wire to the opposite side of the crank pulley (may have to zip-tie in place) - shouldn't be a problem anymore.
Sep 25, 2010 | Cub Cadet Lawn Mower Electric PTO Clutch...
No spark
The selonoid on bottom of carburetor shuts off gas,if bad it will not get gas,It was installed mostly do to engines back firing when shut down this seloniod shuts off gas to main jet so there is no gas in carburetor during shutdown,no gas in cylinder no backfire.
May 12, 2009 | Garden
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
