Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Rheemglas fury 41v50p - Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
  • 92 Answers
SOURCE: flush Rheemglas Fury 22VR75 yearly-increase life of H2O heater?
yes you will increase life if you flush sediment yearly
Posted on Apr 16, 2009
SOURCE: I have an old rheemglas
my top element to the hot water heater is working but my bottom element isnt there both brand new elements and im just not getting power to the bottom element but i have power to the top element is it possible that the top heats first and the bottom heats later running out of options!!!
Posted on Dec 27, 2009
agent91
  • 2100 Answers
SOURCE: How do I turn up
You have 2 thermostats inside of those covers, little things with a dial on them, turn them with a small screwdriver, Don't go too hot or you will be scalding everybody. Hope this helps.
Posted on Oct 05, 2010
SOURCE: I need anode rod for
Anode rods are generic and available from local plumbing supply store or internet.
Just cut it off so it drops into the tank without touching the bottom or sediment on the bottom.
If there is not enough room above the tank to install new rod, then buy anode rod with sausage links.
http://waterheatertimer.org/Replace-anode-rod.html
Open following link for Rheem parts: page 7 shows anode rods
http://waterheatertimer.org/pdf/Rheem-parts-list.pdf
Posted on Jul 04, 2011
SOURCE: rheemglas fury model # 41V50
I have a 50 gl rheem the pilot it doesn't stay lite.
Posted on Jul 21, 2011
What kind water heater can replace Rheemglas fury 81vp20s?
what ever kind you want of course gas for gas and electric for electric
Jan 14, 2015 | Water Water Heaters
No hot water
test the thermostat and the heating elements --also there are resets that can pop push and make sure they have reset
May 17, 2017 | Water Heaters
I have a Park Model RV with a Rheemglas Fury model 81VP205 with no bottom drain. How do I drain the water heater to winterize for the cold Northern Winters?
Make sure it's off (hydro) and open drain at cold line going in bottom wherever you find a drain (usually close to it) going down through floor and outside under trailer. Follow cold line back until you see a line "T" and one line going down under trailer, and open it up underneath. Then open pressure relief valve at top of tank to allow for faster draining .
Oct 14, 2011 | Water Heaters
I need anode rod for my rheemglas fury model # 81V52DT. do you know what the part # is or maybe the dementions. There seems to be several diffrent ones out there. Thanks
Jul 02, 2011 | Rheem 81VP6S/430126 Water Heater
The water leaked out overnight. We have not tried to start it again as it is still dripping water. We have a rheemglas Fury Model # 22-40 natural gas.
Open following link to troubleshoot cause and solutions for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Rusted water heater must be replaced.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
For money-saving water heater information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 28, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
My Rheemglas fury 21DV50 hot water heater pilot goes out about every 2 days for the last week and 1/2. It will light and I'll be able to have hot showers but doesn't last more than about 2 days. Is it the...
It could be a thermocouple but first take the whole pilot assembly out and disassemble it. Clean it very good (compressed air is ok) especially the orifice inside the pilot horn. You may just have a weak pilot. If the flame is in good contact with the thermocouple and problem still exist, then change the thermocouple. I believe in doing the free things first.
Jan 28, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a Rheemglas Fury Model #81V52S C, MFG date 05/2003, 50 gal Does not heat properly--not long enough. I Cannot find a gauge, or know how to adjust tempeture--hope that is only problem--please...
One of the elements may be bad. With the power off check each one with an ohm meter. Should show continuity.
The tube the cold water come in through goes to the bottom of the tank. If it has come loose and the cold water stays on the top you wouldn't have much hot water.
Jan 01, 2011 | Rheem Water Heaters
How do I turn up the temp on my Rheemglas fury 82V80-2?
Oct 05, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Water discoloration. Rhreem serial rh0909ff00279 date 9/2003 model 8v520c 50 gal electric rheemglas fury. prolem occures when we use hot water. tried fixing...backwashed, drained water out completely...
Brown discoloration is evidence of a rusting or corroded steel pipe somewhere in you plumbing system. Trace the water lines back from the faucet and replace all the steel pipe.
White discoloration is minerals that separate out when the water is heated.
You can change the Anode Rod and it should help. It is not an instant fix, the rod will take a week or two to do its job.
If your water heater is still under warranty, call Rheem, they may replace the water heater free.
Sep 07, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
225 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
