Question about Garden
Craftsman dlt 3000
Smoking, using oil. smokes heavy when on slope
  • 28 Answers
SOURCE: 17.5 h.p. b/s craftsman tractor oil pushes into carb. smokes bad!
Make sure it's not overfilled with oil.
if this is not the case, then you have excessive blowby, which is what blows past your rings when the air/fuel mixture ignites. there is only one explanation for this, faulty rings, and that's what it sounds like to me. the blowby forces the oil into the vent leading to the filter, and back into the cylinder, where it burns, creating blue smoke.
Posted on Apr 14, 2009
  • 218 Answers
SOURCE: Craftsman Riding Mower burning oil
Hi,,my name is Keith..and i hate to be the bearer of bad news..but im 99% sure you have broken a ring(s) on your piston..and 1% sure that you have a blown head gasket..i hope this will help..if not please write me back
Posted on Jul 02, 2009
  • 133 Answers
SOURCE: what would cause white smoke from the front of my
It could be your valves. My friends mower was blowing a lot of smoke and I think some oil. I replaced the valves and it runs like a dream.
I can't remember the steps to remove and replace, sorry.
If you are mechanically inclined it shouldn't be that hard. The only problem I has was the new valves (keeper or whatever holds them in place) was different than the old one.
You could call a repair shop and get an estimate.
Good luck. Let me know if this any help.
roundo4
Posted on Aug 16, 2009
Testimonial: "Thanks for your opinion - now I have a few options to consider as I tackle to problem in the morning. Navytime"
  • 138 Answers
SOURCE: Why does my craftsman rider blow out black smoke
could be any number of things - when you changed the oil, was it really runny? was it way overfilled? if runny, possibly the carburetor inlet needle is not shutting off and gas is flooding the crankcase. overfilled? older kohlersmeasure oil level without screwing dipstick in. puking oil into the air filter housing? could be a blown head gasket. OR, it could be as simple as a bad spark plug, it DOES happen
Posted on Aug 17, 2009
SOURCE: husqvarna yth1848xpt with a kawaskie 20 hp puffs black smoke
I had the same problem with my YTH1848XPT . Believe it or not it is simply a dirty air filter....you must remove the filter and blow it out with an air compressor...or better yet replace it. you can not clean it well enough without the force of the air compressor. Mine works great now.
Posted on Sep 01, 2009
Engine growing black smoke
Usually this is a sign of oil being in the ignition chamber. Check the oil level, if too high drain and refill to proper level. Also if you have hills or slopes in your yard make sure that you are mowing up and down not across. If you must mow across the slope make sure to do it with the oil to the downward side. Caution if you do this too often the engine will be deprived of oil all together and seize up.
Apr 18, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Excessive white smoke out of blow by
Just letting you know that white is water, blue is oil and black is gas coming out of the exhaust.
Jul 20, 2017 | Cars & Trucks
Occasional heavy smoke on tickover, but not using oil and oil clean.
HI do you now the color of the smoke
if engine emits white smoke its not burning the fuel
it could be water mixing with fuel = head gasket even tho you
dot have water in the oil
if engine emits black smoke - that's excessive fuel to air ration
check air filter & air inlet to see if clogged
if engine emits blue smoke - excessive oil consumption
cloud be valve seals
Jun 28, 2011 | 1996 Volvo 850
1999 saturn sw has blue smoke coming from tailpipe. I would like to know if it has anything to do with head gasket
blue smoke is usually oil burning- is it light or heavy- if light- change oil and go up one grade- rings are worn- if heavy- time for a rebuild- rings need to be replaced. but for the money on rebuild- could find car newer and lower milage
May 10, 2011 | Saturn SW Cars & Trucks
Using oil...no leakage...no smoking
by recently, do you mean, since it got hot outside? if you're using a multi-vis oil, it gets too thin in hot weather and will "vaporize" and burn, not enough to cause smoking. use a good 30 weight oil. other than that, can't think of anything else that would cause it with no leaking or smoking
Aug 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What would cause white smoke from the front of my
roundo4
Aug 15, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 1987 craftsman riding 17 horse mower. I
Sounds like the rings are worn and letting oil escape past them into the cylinder head. After all, it's been in service a long time. There are several options, including a rebuild with boring out the cylinder and put oversize rings in, buying a new engine and replacing the old one, or just buying a new mower.
Sirwriter
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Best oil to use in tractor lawn mower
Always use straight 30W oil in small four cycle engines if they are not liquid cooled. Use a brand name single weight 30 viscosity oil.
Mar 16, 2009 | Briggs & Stratton Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
