Question about A D S USB Turbo 2.0 WebCam
Driver privileg windows camera - A D S USB Turbo 2.0 WebCam
Hi there.. I have logitech webcam, but i lost the drivers. How do i know the software version? Where can i find it so i can install it..? My Camera has... M/N: V-UBC40 P/N: 861225-0000 PID: LN64287 Made in...
1. the M/N v-ubc40 is the model number
P/N 861225-0000 is the part number.
these are made in china but the Logitech site should have the updated drivers for this model.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12712&section=troubleshoot&crid=480&lt_product_id=3378&tabs=1,3,2,4,5&cl=us,en&p_search_text=QuickCam%20%20Messenger#reqs
this link is to the Logitech site to get the proper drivers for Windows 7 and Windows XP
copy and paste into the address lin in your browser ( Internet Explorer) and click enter. This will bring up the page for you device.
Installation issue as per installation instruction for Windows 7 or Windows XP:
  • If Windows Installer 3.1 (KB893803) is not installed on the system running Windows XP, the software will do so before continuing installation.
  • Installation is only possible when installing with administrative privileges.
Mar 11, 2010 | Logitech QuickCam Express Web Camera
Hi, I've been trying to install the driver disk on my new Acer laptop with Windows 7 for US-144mk2. I press install, select the language and then a message comes up telling me 'your account must have...
Try browsing to the driver disk manually and look for the install or setup program. (.exe).
Right-click it and in the popup menu select "Run as administrator". Maybe the helps.
Dec 14, 2009 | Tascam US-144 Sound Card
LifeCam 1.1 Microsoft XP
You can use your CD to insall the drivers for Vista also. Below is the procedure.
Select the Setup file and right click on it - - - - - >Select Properties- - - - - -> There you will find a menu for Compatability. Select it - - - - - - -> Select the Box to run in COMPATIBILITY MODE OF Windows XP (Service Pack 2) - - - - - ->In Privilege Level, select the box for RUN THIS PROGRAMME AS AN ADMINISTRATOR.- - - - - -> Apply - - - - - - -> OK.
Now run the Setup file and you will be able to install the driver for Vista and it will work for sure.
Apr 24, 2009 | Microsoft LifeCam VX-3000 Web Camera
Installing software for new canon digital camera
Apparently Windows Vista does not require the software and worked without installing it. Regards Trish
Jul 28, 2008 | Canon COLOR IMAGE SCANNER
Vista and driver proplem for Panasonic NV DS 65
what driver are you looking for. camcorder w/ vista should not require drivers as adequate native drivers are included. if it's a specific driver for functionality not supported by native drivers, run the installer in compatibility mode with adminstrative privileges and it should install just fine.
Mar 07, 2008 | Panasonic NV-GS25 Mini DV Digital...
VDR M50 drivers for Windows Vista Ultimate
plug the camera in via usb so the camera shows up as a removeable drive. if it picks up the camera as a DVD burner instead of drive, install the DVD-RAM drivers (in compatibility mode for XP SP2 w/ administrative privileges if necessary) and browse the contents of the disc - copy and paste the VRO file to your hard drive and rename it as an mpg - should be readable at that point. good luck.
Mar 03, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Usb pc camera problem
Install your Usb pc camera under "administrator" user account means that all privileges should be i you so that you can install any driver and software to your pc. may this helpful to you.
In installing disconnect the pc cam to the computer and install the driver. after installing the correct driver connect back the pc camera. the computer will install it for you.
Dec 17, 2007 | Radio Shack VGA PC Camera Webcam
I can't install software or USB drivers in Windows 2000 or Windows NT.
If you see an error message or the software doesn't install correctly, you may not have software installation privileges. Contact your System Administrator. In Windows 2000, do not select Block under Control Panel > System > Hardware > Driver Signing, or your driver installation will not be completed. Select Ignore or Warn instead. In Windows 2000, if you see a "Digital Signature Not Found" screen, click Yes to continue with the installation. If you select No, your camera's USB installation won't be completed.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Cannot access the drive letter associated with the camera
To resolve this problem, do the following: IMPORTANT: You must have full Administrator privileges and the ability to change sharing privileges. Connect the camera to the computer. Double-click the My Computer icon. Right-click the drive letter associated with the camera, and then select Sharing. Select Share this folder. In the User Limit field, select Maximum allowed. Click Apply, and then OK. NOTE: Depending on how the operating system is set up, you may have to do this procedure every time you try to access the camera.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
A D S USB Turbo 2.0 WebCam Logo
Top A D S Computers & Internet Experts
David Payne
David Payne
Are you an A D S Computer and Internet Expert? Answer questions, earn points and help others
