HOW TO FIX CONDENSATION DRAIN ON FUJITSU HALCYON INVERTER INDOOR
MODEL AR-RY16 FUJITSU LAQ INDOOR AIR QUALITY HALCYON INVERTER. IS DRIPPING WATER. HOW DO WE FIX THIS?
notsomot
  • 67 Answers
SOURCE: hi have a fujitsu asta18
I would say that either your unit is short of gas, which is weird because you would of also said the unit has been loosing effiency or I would say that your unit is not level or has came of the back plate. If you pour water on the coil and it drains, I would say that your unit has a gas issue.
If you would like to know anymore please let me know
Posted on Jan 23, 2009
  • 29 Answers
SOURCE: too much water condensation
Check your condensate drain. It could be plugged. Or perhaps you have a crack in the drain pan.
Posted on Jun 21, 2009
daddyo742001
  • 70 Answers
SOURCE: air conditioner dripping water
Try pouring some bleach in drain.
Posted on Jun 28, 2009
SOURCE: Fujitsu Inverter ASTA09LCC Where is the drain tube
It is directly behind & thru the wall to outside next to the refer. piping.Everything goes outside thru a 3" hole. tube should b there.Blow it out.good luck
Posted on Mar 12, 2010
Daniel S
  • 4323 Answers
SOURCE: fujitsu iaq halcyon inverter is
Hi
It is a common issue and occurs due to blockage of air filter, drain and evaporator coils. Please check that there is no blockage in the drainage of inside unit. If so, then please clean it. Also clean the air filter and evaporator coil of any lint or dust and condenser line is mounted properly. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 27, 2011
How do I stop water from dripping from Fujitsu Halcyon ASU18T indoor unit?
Unblock the drain tube and make sure the unit is not level. Condensate needs to run to the rear of the unit by gravity to drain properly.
Oct 01, 2014 | Heating & Cooling
HOW DO I FIX FUJITSU AOU24CL1 SERIAL SIGNAL (REVERSE) ERROR, AT OPERATION STARTUP
Outdoor controller circuit board sounds faulty. This error means that the indoor and outdoor units cannot communicate. Replace the outdoor controller in this case. Check if there are more than one outdoor PCB as others can be damaged as well.
Jul 25, 2014 | Fujitsu HALCYON AOU24CL1 Mini Split...
Water dripping from air conditioner
It's because of non-maintained air conditioner. Clean air filter, indoor coil, blower wheel and also drain pan. Insulate freon pipelines properly and tightly. After that run the a/c. If still water dripping. Check indoor f.motor speed. If less replace capacitor. If f.m. is o.k, check gas pressure. If less, there will be ice formation over the coil and water dripping will be there when it melting. If short of gas, check for leak and rectify. Thanks. Helpful?
Jan 16, 2011 | Fujitsu Heating & Cooling
Too much water condensation
Jun 21, 2009 | Ruud UAKA037 Air Conditioner
Fujitsu remote control unit /MODEL AR-RY16
my remote went blank suddenly. I replaced the batteries and nothing happened. what can I try?
Jun 07, 2008 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
