Question about Bryant 463AAC008BA Air Conditioner
Comfortmaker furnace sa7414 - Bryant 463AAC008BA Air Conditioner
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
Comfortmaker model numbers vr8240m1075
I believe it is an 82% efficient 40,000 b.t.u. furnace. If it is an 80% furnace count the burners each is 20,000 btu 2= 40,000 3 = 60,00 and so on. Hope this helps.
Bob
Jul 09, 2014 | Heating & Cooling
Comfortmaker PAT 336K00A1
Cliff, this is Teng. Look inside your furnace if there is any flashing code. If your furnace is recently installed it should have electronic control board.
Nov 10, 2013 | Comfortmaker 7.5 Ton Heat Pump W...
How can I determine btus & AFUE in a comfortmaker furnace, based on the model #?
The BTUS are part of the model number and the Manufacturer will give you the AFUE rating or just call a local comfortmaker wholesaler listed locally. Good Luck
Aug 14, 2013 | Heating & Cooling
Can anybody identify this airhandler/furnace? MOD# GNJ075M12A1. SER# NTN5075BFA1. THERE IS ALSO AN A-COIL IN A CABINET BUT I DONT THINK IT GOES WITH THIS UNIT. MOD#C2E30B-1A SER# 6002B0483. IT ALSO HAS AN...
Your Gas Furnace is a Comfortmaker.
The Evaporator Coil is an Armstrong.
Hope you find this to be very helpful.
Please leave a rating for me. :-)
May 14, 2010 | Heating & Cooling
Comfortmaker furnace will not light!!
Make sure you have gas to the unit and the switch on top of valve is turn to on. Can you here the gas valve click? It igniter comes on and a delay and the gas valve should come on. Kill power to furnace to reset control board. Rus Let me know how it goes.
Nov 17, 2009 | Heating & Cooling
Furnace will not kick on.
sounds like you have a problem with your module, it is kind of triky troubleshooting the module you have to know what you are doing, and becides it is a spencive part,and perhaps you may want to try to buy it.Or we can try something alse like whats your location?
Nov 15, 2009 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
