Question about Whirlpool duet Washing Machines
Falla f-11 lavadora carga frontal whirlpool
But no water gets into the motor turns and throws the fault f-11
3 Suggested Answers
Jahn27
  • 1554 Answers
SOURCE: necesito el manual de instrucciones
Here's the Instruction Manual for your Whirlpool Duet Front-Load Washer.
Whirlpool Duet Front Load Washer Instruction Manual
Posted on Dec 21, 2010
jsrock516
  • 5911 Answers
SOURCE: My machine will not go to wash mode....it gives a
"F11" is a Serial Communications error. This is an indication of a communications problem between the Central Control Unit (CCU), Motor Control Unit (MCU), or the interconnecting wiring between the two. The following link explains:
http://www.fixya.com/support/r3608695-f11_error_code
You will need to remove the top panel of the washer and check all the connections at the CCU to be sure.
FYI: If you do determine that the CCU is the cause of the problem, some sites may carry a refurbished version that costs less than a new one. For a full explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices will vary between sites so shop and compare. The first three sites on the list include helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. If you have questions, or need additional assistance, please post back and let me know.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Posted on Feb 03, 2011
Union de cables en el motor de lavadora whirlpool
hola tengo una lavadora duet sport de whirlpool y me aparece el error f 25, aveces termina de lavar o simplemente lava y luego no enjuagua, y hace ruido como traka traka gracias.. karina reynoso
Feb 18, 2012 | Whirlpool Washing Machines
Lavadora maytag mlg 2000 aww la inicio en lavar esta lllenando a los 20 segundos se apaga , la pongo a exprimir tira el agua pero a loa 20 segundos se apaga doy gracias
hola por que cuando encho ropa a la lavora y le pongo el ciclo adecuado y a los 20 min o segundos me aparece un error f20 mi lavadora es maytag frontal ke puedo hacer????????
Jan 12, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
Que significa GEARBOX ENGINE SYSTEM FAULT esto
Significa "FALLA EN LA CAJA DE CAMBIOS Y DEL MOTOR" si cambiaste la bateria es muy probable que no le hicieron un respaldo, no se puede desconectar al 100% la bateria, normalmente de corrije sola esa falla, si no acude con algun mecanico que tenga scanner y te reset la falla, la otra falla posible es el sensor de oxigeno, apaga el auto completamente y espera un minuto y reintenta, si la falla sigue puede ser cualquiera de las 2 que te dije, suerte!
Nov 08, 2010 | 2002 Jaguar X-Type
Tengo un problema con mi lavadora whirlpool duet cuando la enciendo para lavar me presenta un fallo en la pantalla. y sale fallo 22.que es el swich de la tapa.pero se lo cambie por uno nuebo y sigue...
ke tal tengo una lavadora whilpool duet pero al encenderla y poner el ciclo de lavado normal me prtecenta una falla dice falla 11 y no se que es esta falla me podria orientar?
elrayo_0609@hotmail.com gracias
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Como ensamblo una lavadora acros
Could you please translate to English?
Nov 09, 2017 | Whirlpool Washing Machines
Tengo una lavadora Whirlpool modelo LXR7144EQ1 que al exprimir la ropa no gira la tina si me pueden Ayudar de una Resolución de este problema
tengo una lavadora whirlpool, el problema es que no gira para exprimir, todo lo demás funciona, el motor recibe la señal para la función exprimir, sin embargo la transmisión no funciona.
Jan 09, 2010 | Whirlpool Washing Machines
WASHER CUTS OFF IMMEDIATELY AFTER BEGINNING TO IMPUT WATER, THEN SHOWS "FAULT 11" DON'T HAVE SER. MANUEL TO DETERMINE WHAT FAULT 11 IS, CAN YOU HELP? THANKS
F11 is a motor control board or if u are lucky a loose connection at the upper control board ....motor control is down at bottom main control is at the top back of washer
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi, My washing machine is not completing the washing cycle, it gets stuck when the water should go out of the tank. There is anormal noise like if something does not have the strengh to pull the water...
well Xavier, looks like you have a bad water pump in your machine, or its clogged up with debrie, either way you will have to have a qualified tech check it out unless you are extreamly handy with replacing pump motors, its not to easy to do, hope that helped ya
Jan 19, 2009 | Refrigerators
Washing Machines Logo
47 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
