Question about Hayward H200FDN Low NOx Natural Gas Pool or Spa Heater
Code error i have error code CE when i turn the heater on???
3 Suggested Answers
thepool
  • 78 Answers
SOURCE: Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Posted on Apr 23, 2010
  • 760 Answers
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
Ce code
CE
Communication error
If communication between the ignition board and the display board is not established within 3 s of power-up an error will be displayed. After communication is established, if it is lost for 30 s, the error will be displayed. The error code will be cleared upon a valid data exchange between boards
All you can do is remove the panel and make sure that the connection between the two boards is good and dry. Other than that, you will be changing cable from the lower board or the lower board itself.
Jul 02, 2014 | Hayward H Series
The CE code is showing on screen
Communication error
be cleared upon a valid data exchange between boards.
May 18, 2012 | Hayward H-series Electronic Gas Pool...
I have a CE error code on my Hayward Pool heater. This happened after a heavy rain. Should I try a hairdryer?
According to a Hayward manual the CE error code is a communication error. Here is quote, "If communication between the ignition board and the display board is not established
be cleared upon a valid data exchange between boards."
I don't think you can do any harm by turning the power off, opening the cover and drying everything out the best you can. In addition, if you carefully unplug and then replug each of the connectors then that may also help correct a communication error.
I hope this helps and please vote on this answer. Thank you.
Aug 26, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
The code CE is showing on my Hayward pool Heater what does that mean and can I fix it
I have just repaired my H400 series pool heater from the 3rd CE error in only 3 years since the pool and heater were installed. In each case the circuit board (F0059-456600) was in some way to blame .... I will explain.
Case 1 : Only months after installation the CE error came up. Rain water had got in around the display module and water-damaged the circuit board. It was replaced under warranty. Since then I keep a big plastic lid covering the display unit when the heater is not in use.
Case 2 : 1 year from new the CE error came back. On investigation it was found that a rat had managed to get inside the heater (there are big gaps around the pipe entries) - it had then partly chewed through the ribbon cable joining the two circuit boards together. Display circuit board was replaced at my cost - and all was well again. I also rat-proofed the heater - eliminating all the big openings with chicken wire.
Case 3 : Fired up the pool heater for the first time this year and CE came up. I pulled the display module and this time found obvious signs of blackening / burning on the display circuit board under the big green resistor (R1). Luckily I had kept the old circuit board from the previous time and was able to make 1 good board from the two I had - back in action now.
So in my experience it has been the display circuit board each time - and it only takes a phillips-head screwdriver and about 10 minutes to get it out.
Jul 27, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
Error code "CE" is being displayed. I was told to replace the control board, which I did. Still getting the error message. Does the system need to be restarted to recognize the new board? If so,...
Error code "CE" is "Communication Error" the manual for your heater gives the following description.. "If communication between the ignition board and the display board is not established within 3 s of power-up an error will be displayed. After communication is established, if it is lost for 30 s, the error will be displayed. The error code will be cleared upon a valid data exchange between boards.
That being said If you replaced the board I would check all your connections closely and look for bent pins, corroded/oxidized connectors, etc. If this still does not help give Hayward a call, they usually give pretty good support. You can reach them at 908-351-5400
Sep 19, 2010 | Hayward HSeries Natural Gas Pool Heaters...
I have an H400 heater (H400IDL2) and I get the CE trouble code, how can you determine which board is bad?
CE is a communication error between the display board and the ignition board. If you've had a lot of rain lately it could just be that moisture inside the unit is causing the error rather than a bad board. Take the cover off and blast the inside with a hairdryer for a few minutes, making sure to get the boards and connecting wires. That sometimes clears the error.
Jul 05, 2010 | Hayward H Series Pool & Spa Heater 400k...
Jul 04, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
CE ERROR
CE is a communication error.
This is an automatic check performed anytime the unit is powered up. If there is no data communication between the main panel and the ignitor you will get this code within 30 seconds.
If communication is re-established this code will disappear.
DO NOT do any of the following with AC power on / to the unit.
First check the ignitor then, the wiring and terminals from the ignitor to the main board.
There just might be a corrosion problem with the circuitry or corrosion on the main board itself.
Thanks for using FixYa.
Kelly
Apr 06, 2010 | Hayward H400FDN Low NOx Natural Gas Pool...
Feb 15, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
Hayward H200FDN Low NOx Natural Gas Pool or Spa Heater Logo
20 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
