Question about Mitel Lands Phones
My Mitel SX-50 dial pad on console does not work. Help
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Look for a button on the console that is stuck down. This will cause the problem you are describing. If this is not the case, you need to get with a Mitel vendor to get the console repaired and refurbished.
Posted on Feb 13, 2014
4 Suggested Answers
SOURCE: Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
Posted on Dec 17, 2008
cnavarro
  • 2460 Answers
SOURCE: SX-50 Attendant Console Failure
The console uses 3 pair USOC wiring from the console to the jack on the control card. Look at the Mitel provided cable from the console. It should be 6 pin and you can make sure the console is functional by moving it to the cabinet and plugging it in. If it works, you need to cable 432516 straight through on a 6-wire modular plug and terminate it in the same order on a jack where the console is. They must be paired for the long run.
I have a huge non-indexed pdf of an SX-50 if you need it. The console explanation is figure 5-14 of the -200 practice if you have it.
Carl
Posted on Mar 16, 2009
cnavarro
  • 2460 Answers
SOURCE: Our phone won't allow us to call 866 numbers
It's in a table of allowed numbers. If you're familiar with the system, you ought to be able to find where 800 and 888 are allowed. Just add 877,866 and 855 as entries.
If ARS is implemented, you'll find your entry in the 700 table, maybe :-)
I don't envy you if that is the case.
Posted on Jun 04, 2010
Why my mitel sx-50 shows message on console no communication?
The phone line between the SX-50 console and the main control is disconnected or the console may need to be rebooted (unplug the phone line then reconnect it). If this doesn't solve it then contact your PBX system support person.
Jul 14, 2014 | Mitel Lands Phones
Mitel SX-50 phone console keeps ringing for no reason.
first make sure it is not a line problem by disconnecting the phone line when you get the rings, then make sure it is getting proper power to the unit. if it does not have electric plug look for batt in unit and replace. If unit is dirty, gummed up try blowing out with air, before giving up on the unit. good luck
Jun 02, 2014 | Mitel SX-50 Console White Phone...
Printer queue is full on sx-50 attendant console
This is explained in the SX-50 system maintainer's handbook, 2 copies of which came with your SX-50 when it was new. However, this is a pretty old piece of phone equipment (30+ yrs) and when these systems were originally set up by outside service companies, it was not unusual for them to take the manuals so that customers would not be tempted to tamper and would call the service co instead. However, all is not lost. There is a very good Mitel support group on Tek-Tips (www.tek-tips.com) On tek-tips the Mitel forum is under Home->Forums->Wiring Closet->Phone Systems->Mitel Networks Solutions Forum. You will need to register in order to post. Hope this helps.
Apr 19, 2014 | Mitel Superset 4015 Corded Phone
How can i fix lock on mitel sx50 console ?
Lock? Can you elaborate? I hope you've gotten this resolved already.
Mark
Jan 12, 2011 | Mitel 9104-001-000 Power Supply SX-50...
Mitel sx 50.. How to unlock room phone..how to take it off from do not distrub(in room phone)? Thank you so much
Attendant
To apply Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number.
• Press the DND ON softkey.
• If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension.
• Press the EXIT softkey.
To remove Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB.
• Press the DND OFF softkey.
Oct 13, 2010 | Mitel 9104-001-000 Power Supply SX-50...
Carl
Mar 15, 2009 | Lands Phones
Nov 11, 2008 | Uniden 5.8GHz Cordless Phone
Lands Phones Logo
74 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
