Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Freezer not Freezing..compressor going off and on!
The Freezer side quite working...checked the compressor..kept going off and on..and is very hot to the touch! There us a white and tan box connected to the compressor that keeps clicking off...and on! The compressor will come on...run for about 30 secomds ...and click off again??? Can you help me? Thanks,,,,
  • 63 Answers
Let cool down for a few hours like all day then try replacing the realy over load thats in the white box u see buy a 3 n 1 start kit it might start the compressor plus make sure the condensor fan is running too.
Posted on Aug 29, 2007
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
My freezers compressor is getting very hot and the freezer is not freezing
Fridgidaire Upright Freezer appears that the compressor is getting hot enough to burn ( serious discoloration) the linoleum below the freezer.
The compressor is hot to the touch.
Freezer is working just fine.
What to do?
May 15, 2010 | Frigidaire FRS26R4A Side by Side...
Whirlpool 25.6 cu. ft. side by side Refrigerator with in door ice
The process of Refrigeration is for one section to be hot while cooling another section. I.e freezing in one section result in the heat build up and dissipattion else where. Any compressor working properly is going to be quite warm to the point of being hot to the touch when working NORMALLY. There is nothing that you need to do for the continued safe operation of your compressor. If your freezer has ice build up again in the near future your uint is not defrosting properly. If it functions normally after 2 or 3 days of use then you more than likely had a one time buildup of ice usually caused by someone leaving the door partially open
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer has stopped
If it is a frost free side by side fridge/freezer, check evaporator fun in the freezer. While doing that, check is evaporator is full of ice.
if the evaporator is iced up and the fan can spin freely, you have a broken fan. Replace it.
If evaporator and the fan are iced up, you have a broken thermostat. Defrost ice with hot water.
Turn it on, if it starts to cool effectively, replace thermostat.
Oct 11, 2009 | Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Freezer not freezing frig not cold
the compressor with a picture of an Indian, its a techumseh. Is the compressor running? If not, could be stuck in defrost mode. Since you have looked at the compressor, there is two lines that go to it. If there is an oil cooler, then 4. Follow the line, smaller of the two that goes to the condensor, rad. With the fridge running, use your hand to feel how hot it is, if you find it hot enough that you can't leave you hand on that line, then its an inneficient compressor.
Feb 09, 2009 | Frigidaire FRS3R4E Side by Side...
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
112 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
