Chigo air condition f5 - Heating & Cooling
What does error code L1 mean on my chigo air conditioner unit
When posting hardware questions, it is useful to post brand and model number. There are a number of Chigo air conditioners. I have examined an error code page for the brand and the error L1 is not listed. However, on page 25 of the following manual, L1 is identified as a current transformator of which there can be a No-voltage for over-c
urrent detection circuit. See 4) Electric control panel detection sub-number 3 on that page.
http://www.investliving.se/upload/images/Produkter/Luft-Luft/New%20Basic/Service%20Manual%20New%20Basic.pdf
Dec 18, 2017 | Heating & Cooling
F5
Hi, F5: Outdoor discharge sensor open or short circuit.
Sharp error codes
Air Conditioning Fault Codes
Mar 04, 2014 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
PANASONIC DMR BS850 SHOWING ERROR CODE F5 202 CAN IT BE FIXED
hi,
Fault Code At Remote = F5
Indoor Unit PCB
LED1 = Lit
LED2 = Lit
LED3 = Lit
LED4 = Lit
Outdoor Unit PCB
LED1 = Lit
LED2 =
LED3 =
LED4 =
Measuring Of Fault Code = Signal from RC to ID faulty.
Feb 28, 2014 | Heating & Cooling
Chigo 12k BTU A/C E4 code on the display
The "E4" error code indicates a host of possible problems. More than can be listed here. So, I have included a link to your model's Service Manual that you can download & print if you so desire. Pay particular attention to pages 32, 33 & part of 34
www.chigo.us/support/downloads.html?download=3%3Aservice-manual
I hope this helps you and thanks for choosing FixYa.
Aug 23, 2011 | Heating & Cooling
What does the E4 message on the Chigo unit mean?
Chigo doesn't have an online manual, but here is the page with their contact info on it. Hope this helps some:)<br /><br />http://www.chigo.co.za/index.php?option=com_contact&amp;view=contact&amp;id=1&amp;Itemid=4<br /><br />
Aug 25, 2010 | Heating & Cooling
I have a Chigo Mini Split KF-32GW/A. What is
E5
PG motor
display at
off state
flicker 5/7
SEC
display
at off
state
no feedback
signal of indoor
fan
1、Check whether two sets of plugs on the outlet end of
the motor have loosed from the socket of the
electric control board, insert it firmly when loosing.
2、Check whether the indoor motor has damaged, the
motor should be replaced when it is damaged
3、 Check whether the controllable silicon and other
components on the electric control board have
damaged, replace the controllable silicon or electric
control board when they are damaged.
Jun 12, 2010 | Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
