Question about Mitsubishi WS-65869 65" Rear Projection Television
The green blinking light won't turn off and won't respond to reset or unplugging the TV. I found a possible repair for a model WS-65813 by replacing 4 capacitors on the DM Board, but the WS-65869 seems to have a totally different DM Board. Does anyone have a fix that a non-electonics expert may be able to complete?
IF YOUR LOCATED IN L.A OR OC COUNTY HIT ME UP ON MY EMAIL. I CAN HELP WITH THAT :-)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/ramiro_eafa48888ae9792a
Posted on Nov 21, 2008
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Posted on Sep 26, 2007
Jun 24, 2013 | JVC LT Televison & Video
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Apr 15, 2010 | Televison & Video
Sep 08, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Dec 15, 2008 | Sony KDS-60A2000 60" HDTV
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Apr 15, 2014 | Mitsubishi WS-65869 65" Rear Projection...
Aug 27, 2017 | Mitsubishi WS-65869 65" Rear Projection...
Aug 24, 2011 | Mitsubishi WS-65869 65" Rear Projection...
716 people viewed this question
The same problem with Mitsubishi WS-65813..green light stays on blinking. Tv won't turn on or turn off.
Same Model TV same problem with blinking green light and tv wont turn on. Had a tech come out to diagnose the problem and he said it was due to a bad signal board. $500 for part $200 for labor. Haven't got a repair yet b/c want second opinion.
I have WS 65869 model, the tv will work for about five minutes, then the color will turn to black and white then picture is gone, only green screen sometimes blue screen will appear, have to turn it off manually. I tried playing a DVD, the picture looks ok for the first three minutes then it will turn green or black and white and the screen will turn to blue or green. I paid more than 4k for this TV in 2001 or 2002, with today's prices, is it worth fixing this TV or buy a new one. Can anybody have suggestions on how to fix this problem, maybe I can stretch the life of this TV. I like the picture and the sound. Thanks...Frank from San Diego
Power failure shut down my Mitsubishi WS-65869 projection TV. On powering back up the infamous blinking green light came on and failed to respond to the Reset buttom. How can something so frequently encountered in the normal life of an electronic device cause such a comlete system failure? So, what does one do to correct this problem? Have done the Reset and unplug the TV attempt but no results. Have called Mitsubishi but they are of no help.
Have a Mitsubishi ws-65869. Blinking green light problem. Have had it looked at and repair company says that Mitsubishi is not making the part anymore. Bought it in 2002. Don't want to throw TV away. Why is this happening to all the Mitsubishi TV'S? Paid so much and then to treat it like a disposible TV?? NEED HELP!
identical problem here.
Due to a power failure my Mitsubishi WS-65869 projection TV won't turn on. On powering back the blinking green light came on and failed to respond to the Reset button. I have kept it powered off for 24 hrs and turned back with same blinking green light. I have recently finished the 5 years of extended warranty. Would some one suggest me how can get this problem fixed? Sanjoy
We have exactly the same problem. The power went out the other day. I came home and tried to turn on the set with the remote. Nothing but a green blinking light. Pulled the plug for 24 hours and the just kept blinking when plugged back in. Ours is a 65 inch projection TV model # WS-65813
Any new ideas ???
Same exact problem. Powered down, moved the set to my new house. Now after I turned on, I have the infamous blinking green light.
After a power failure, I have a blinking green light and now the my TVwont respond to any reset or disconnecting it from the power supply. Can someone help? My TV is a WS-65869.
i have the same problem it have been blinking for a month and i have restarted is and unplugged it but nothing can someone help
If you have Model WS-65869, I found the DM Board in a covered box in the lower left hand side of the TV after opening the back panel. I don't remember the details of how I got it out, but I had to disconnect several wires coming out of it (be sure to make a sketch so you know where to reconnect). Once you have the box removed, just take off the cover and you should see the capacitors. I did a lousy job of replacing my capacitors, but it still worked - if it happens again, I'll probably take the board to a professional so I don't damage the board.
Hope this helps.
I just now paid TV technician $190.00 to tell me the DM module is not a replaceable part from Mitsubishi anymore. I paid another one $50.00 three days ago to say it coulodn't be fixed. (Should have listened to the $50 guy).
I called the place where I bought it 6 years ago, and they said Mitsubishi will not service it because it is CRT technology, and that's old news.
I paid $5000.00 for this TV 6 years ago, and now it's junk. No more Mitsubishi for me.
Help!!!! Tjis was my late fathers TV and I would like to keep it if at all possible. Is there a fix for this that won't cost $600-1000?
We have same problem on the 65869. Light just keeps blinking and won't respond to anything. Do u know where I can get the capacitors and about how much they will cost me?
