Question about LG WM2077CW Laundry XL Front Load Stackable Washer
I need help
I started a load of laundry,small load,,it worked fine until there was 1 min remaing so i hit the pause cancel button to pull laundry out but then i noticed that the light was still on for rinse cycle,,so i hit the button to restart but it wouldnt do it, so then i hit the cancel button and nothing cleared so i rehit the start hold button,then nothing so i again hit the cancel button,its still blinking on 1 min remaing but nothing is happening what do i do
Try pressing the pre-wash, extra rinse and timer buttons all at the same time and this should take off the child lock it worked on my LG washer Model No. WM12235FB after I leaned against it and put on the child lock by accident.
Posted on Oct 01, 2008
  • 3 Answers
I think you may have accidentally put it into Child Lock mode which will remain until you unlock it. Read you owner's manual I came across this info while looking for something else and had no idea this feature would lock you out of operating the buttons on the machine as well as opening the door.
Cindi d
Posted on Jul 10, 2008
    Sergeant:
  • 271 Answers
Un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
Posted on Jan 06, 2008
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fisher & Paykel dryer DE60F60EW1 has suddenly stopped working when I tried to change the program. How do I reset the machine
Here are a couple of possible reasons it stopped and solutions from the manual.
Adding/removing laundry in standby mode
If you want to add or remove laundry into/from your machine after the drying programme has
started, put the machine into Pause mode by pressing the START/PAUSE/CANCEL button. The
drying process will stop. Open the door at Pause position and close it again after adding or
removing laundry. Press START/PAUSE/CANCEL button to start the programme.
Any laundry added after the drying process was started may cause the already dried clothes in
the machine to intermingle with wet clothes and the result will be wet laundry after the drying
process is over.
It is not recommended to add laundry after the programme is started as it will increase the
programme time and energy consumption.
Childproof lock
There is a childproof lock to prevent any programme interruption due to the pressing of keys
while the programme is on. The loading door and all keys except the ON/OFF key on the panel are
deactivated when the childproof lock is active.
In order to activate the childproof lock, press on the StARt/PAUSe/CANCel and BUzzeR CANCel
buttons simultaneously for 3 seconds.
Fig.6 Using the
childproof lock
To start a new programme after the programme is over or to interrupt the
programme, the childproof lock should be deactivated.
To deactivate the childproof lock, press the same buttons for 3 seconds.
Two beeps will sound when the childproof lock is activated. A single beep
will sound when the lock is deactivated.
I was able to view the manual by a Google search and the third item on the Google search list was the manual, but it would only come up by selecting "quick view", otherwise it would crash the Acrobat reader plugin.
Jun 03, 2012 | Toys
I started a wash cycle, needed to add more laundry, press the pause/cancel buttom twice, now I can't start it again. When I press the start buttom everything goes blank, all lights go off
Remove the power plug and keep aside. Keep the sart button pressed on to discharge. After 15 minutes switch on the washer while holding the pause/cancel button.
If the set does not come back to life it iis possible that the main board has encountered some errors.
Repeat the procedure after some time.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How can i turn off key symbol
Hello Lucy and welcome to Fixya.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's... 1) Turn the program selector to any program as you would doing laundry. Add your items... 2) When you close the door the "start/pause" light flashes... 3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved. 4) Press the "select" button until the desired volume or "off" is reached/displayed. 5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed. As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Jun 16, 2010 | Bosch Washing Machines
Lights Blink washer wont start
Check user manual for programme reset , but poss. hold start button on for minute or try same with cancel button.
Nov 02, 2009 | Washing Machines
Washer won't start/lights on
ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2077CW Laundry XL Front Load Stackable Washer Logo
384 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
