Question about Welding Tools
Cutters are not moving on my tanaka tbc 230 hedge cutter
The cutters have just stop moving after about 2 hours of cutting .the engine is still operating
trippssmengi
  • 76 Answers
SOURCE: Long reach hedge trimmer
Try loosening the bolts up on the blades just enough to allow the washers to move freely a little, spray the blades down (but don't soak them ) with WD40 to lubricate the blades, that should solve it. If that doesn't do it then you may need to pull the gear housing cover off to see if something is jammed.
Posted on Jan 14, 2009
johnr1959
  • 56 Answers
SOURCE: plasma cutter wont cut steady
Is your air compressor able to keep up with the continuous regulated air flow?
If positive air flow is not constant same pressure all the time
cutting will stop..>>
Also if your movements are to fast and or material to thick machine will behave that way..
Posted on Jan 30, 2009
SOURCE: miller plasma cutter stops cuttingafter a few seconds
the cutter probably has a built in current monitor. that trips out then resets itself. try a lower current.
Posted on Mar 24, 2009
slohry
  • 87 Answers
SOURCE: thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Posted on Apr 10, 2009
  • 192 Answers
SOURCE: Elna 704 serger sews well but cutter won't cut.
Make sure that the blades are being held firmly together. I have seen the knob used to lower the moving blade come loose and releases much of the pressure intended to hold the blades together.  If so, the set screws on knob have come loose.
Posted on Sep 06, 2009
Tanaka TBC 4228 Primer Bulb IS TI TWO PIPES OR ONE PIPE
2 Pipe bulb usually, as it is sucking in then pumping out fuel.
Feb 20, 2015 | Garden
Thihl HL75 hedge trimmer engine will not run at full speed
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Welding Tools Logo
26 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
