Question about LG 42" 42LD460 PAL-N, PAL-M, NTSC Multi System TV for North and South America
TV turns off on its own frequently...
I have a LG LDC Tv - lg42ld460 bought 2 years back. Now I have a problem,which is while watching TV programs, the TV turns of by its own and the red light blinks. When I turn it back on, it plays for around 15-20 mins and then again turns off on its own and red light blinks. I have checked the wiring, installed a voltage stabiliser. Checked the TV settings and also did a factory reset but no luck. Can someone please help me what can be done.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Capacitors in the switch mode power supply
Posted on Oct 28, 2017
5 Suggested Answers
SOURCE: Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Posted on Aug 18, 2008
  • 3 Answers
SOURCE: no sound though home theater when watching tv
There is an orange button on the remote, half way down in the middle. I belive it has orange lettering and says something like "TV-?" press that, and the sound should start to come through your speaker system. You can then use the original remote that came with your TV and turn the sound off on the TV to use just the theatre system. I noticed that if you use the TV speakers in conjunction with the theatre system, that it echo's.
Posted on Nov 26, 2008
lynchms
  • 93 Answers
SOURCE: lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Posted on Feb 17, 2009
SOURCE: LG wireless dvd reciever system
Hi, I had the same problem, it seems to be a design error of LG or a typical problem with some component in the wireless transmitter. It is basically caused by the transmitter heating up, leading to a clock drift with the result of the receiver losing the signal. I tried to cool the transmitter in the fridge before using so it will run for about half an hour before producing this error (depends on the room temperature as well). My solution is to remove the plastic case of the transmitter unit and place it in a cool place where it does not catch heat from other devices. Without the case it does not overheat and also takes less space, just be careful if you have children. I placed the naked Tx unit behind the TV so it does not matter. Hope this works for you as well.
Posted on Aug 31, 2009
I bought a LG tv model# 22LG3DCH and I cant program the chanels it says no signal but other tv pics up just fine.How do I fix it?
[PDF]Commercial Mode Setup Guide - LG.com
www.lg.com/.../32ld345h-commercial-mode-setup-guide....
LG ElectronicsThe model and serial numbers of this TV are located on the ... However, there is noguarantee that interference will not occur in a particular ... the TV by the hanging power and signal cables on the back ..... program guide (EPG) data provides additionalchannel and program ..... If set to 1, cannot tune from current channel.
How to resolve the No Signal or No Channels in Master List ...
? 2:07
https://www.youtube.com/watch?v=Tk7EUAEncsQ
Oct 6, 2014 - Uploaded by VIZIO
How to resolve the No Signal or No Channels in Master List message. ... Show more ... Why Does My TV Say ...Missing: 22lg3dch
LG TV "No program information" - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/55640-4-program-information
May 24, 2012 - 7 posts - ‎5 authors
I bought a 35" LG TV a few months ago. ... TV on and it was (and still is) displaying "No program information" instead of ... All other information about the current channel is displayed OK. ... Diamondhead said: ... Can't find your answer ? ... a LG Sound BarModel LAS350B to a Toshiba TV Model 32C110U1?
Jan 05, 2016 | LG Televison & Video
Tigerdirect.com
Have your TV check at Sony store.
Oct 22, 2017 | Sony BRAVIA KDL-52XBR4 LCD TV
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Programming wrking fine, however i have no channel guide/listings
Call LG. They will have you go through diagnostics over the phone and ask for diagnostic data the TV has in memory.
I have done this about 10 times and my TV usually loses all it's TV guide data after I customize my channel listings (delete all the channels I don't susbscribe to). Within a day or two of calling them, my TV Guide is back to normal.
I will never buy another LG TV. Thank God I bought the extended warranty. I've had the power supply already replaced (this is also the 2nd set..replaced 1st set due to same issue), TV turns itself on at times ( in winter - low humidity/static electricity??), and loses TV Guide listings on a frequent basis (after I change the channel map).
Nov 26, 2008 | LG 42LB1DRA 42 in. LCD Television
Plasma screen color problems
Hi
I just bought a 42pc5d plasma tv it's an LG I bought it in Sept. 07 it started doing the exact same thing your talking about here the red glow type thing. Luckily for me and I hope in your case that the tv is under warranty, although if you know someone or even a repair place I don't think it would cost much to fix (just a guess but the guy told me that it was an easy fix so don't let them try to screw you). It really is a simple fix according to the tech. You need to adjust the voltage. He took the tv and watched it until he saw the red and adjusted the voltage and I had my tv back the next day. This was about a week ago and I haven't seen it since. I hope this helps and I hope you have a warranty. By the way LG comes with a 2 year manufacturer's warranty standard so if you didn't get an extended warranty from where you bought it if it's less than 2 years old call LG and they will arrange to have it fixed that's what I did. Here's the number 1-888-542-2623. Good luck.
Dec 27, 2007 | LG 42PC5D Television
TV WILL NOT TURN ON
i HAVE THE SAME TV, SEEMS LIKE THE LAMP IS OUT. BUT ONLY TWO YEARS USE? WOW. iVE HAD MINE FOR 3 YEARS WITH ATLEAST 6 HOURS PER DAY USE. WELL GOOD LUCK AND DONT LET A TECHNICIAN CHARGE YOU 200 FOR LABOR TO TAKE OUT A FEW SCREWS
Dec 17, 2007 | LG 52SX4D 52" HDTV
Red or green tint on LG LCD 32" TV
Misaligned white balance adjustment. If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 14, 2017 | LG Televison & Video
LG 42" 42LD460 PAL-N, PAL-M, NTSC Multi System TV for North and South America Logo
56 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
