Question about Wine & Spirits
Angkor cambodia what is angkor cambodia
AOTO CAD VIRUS CAMBODIA
Hello, Don't worry, if your autocad program infected by virus cambodia no need to worry,
because this virus khmer cambodia autocad anti-virus can protect 100% use normally.
Please send your email to me through my private email: (reachsamnang@yahoo.com)
I will send soft khmer cambodia autocad anti-virus protection to you as soon as possible.
Feb 11, 2013 | Autodesk AutoCAD 2010
Bought sim card in Cambodia for my blackberry. I can text and receive texts, but when I make a call to the same number (home, USA, CAlif) it doesnt work. How come I can text the number, but not call?
Derry, if your numbers are starting with 00 and then countrycode then local number, if yes change initially 00 with +, and then try again, if no then edit number and insert + and country code, then try to make a call. if problem persist try to check your call settings for international calls if is not a barred if yes then remove all barring calls, if problem persist try to do factory reset of device.Best of Luck.
Jul 16, 2012 | RIM BlackBerry? Curve 8330 Cellular Phone
I need the instruction to set the machine right for sending a fax from Cambodia to Australia or receiving a fax from Australia. I typed number in Australis to send a fax but my friend there did not receive...
There is not much to do than to set the machine in the fax mode after setting up the time and data as instructed on the interactive menu .
You need to type the STD code of cambodia and the number of the fax there which must also be active. Make sure that you enter the correct local code if the number is in sub-district.
Ask your friend to send the fax after placing your machine in fax mode.
Make sure there is dial tone and you are able to make calls using the telephone mode.
if not check the connection.
Feb 15, 2011 | Brother MFC-7340 All-In-One Laser Printer
I want to know the iriver branch in cambodia.
there is no branch listed but you can try international or any other south asia branch
  • http://www.iriver.com/
Feb 21, 2010 | iRiver E100 Digital Media Player
Hi my name Panha and i am from Cambodia.I want to know why when i copy some mp3 go into my phone(model LG KU990)it didn't show anything.I don't know how to fix this problem.I am looking forward to hearing...
Hi Panha, Id say that maybe you have run out of memory space for storing your MP3 files, try deleting some already present or a few pictures/vids, and try again, hope this Austalian helps you in Cambodia. cheers
Nov 05, 2009 | LG KU990 Viewty
Phone request me to enter the sim code when i used Cambodia's SIM
not sure if this works with the 2008 but its something you can try, i put a sim card in my LX and was asking for a special code to unlock the phone, well right now tmobile isn't unlocking the sidekick, but you can trick the phone into using the sim card. First go to your settings, go to "SIM Center" and click on disable sim lock, enter in whatever your sim password is (if you dont know your sim password get your PUK (pin unblocking key) number which customer service will give you if you call 611, you can change that SIM pin by typing **05*PUKnumber*newpin*newpin#) now if you wanted to change it to "0123" if your puk was 9483992 its 7-9 digits you would type **05*9483992*0123*0123# now your sim pin is 0123. (trying not to make this super complicated) it will say sim pin not accepted click ok, now click change sim pin you can type the same sim pin 3 times if you want, 0123 0123 0123 now at the top of the screen bars will show up with a white phone beside it, go to Settings-Network Options-Scan and Select Manually, the SIM network should come up, click ok when it finds it and it will connect, now you can call and text on whatever sim you have in the phone
Mar 04, 2009 | T-Mobile Sidekick
Wine & Spirits Logo
81 people viewed this question
Top Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
