Question about Garden
Levelling the cutting deck for an mtd rh115/76 sit on
Model number 1301452c622
  • 148 Answers
SOURCE: Need deck belt for older chaftsman mower
Try www.searspartsdirect.com and type in your model number. They'll let you know what is still available and you can order directly from them online.
Posted on May 19, 2009
lester482529
  • 226 Answers
SOURCE: Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
Posted on Jul 03, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
lester482529
  • 226 Answers
SOURCE: I need a diagram for the deck belt on my Cub Cadet
go to partstree.com put in your make &model #.then clickdeck assembly.hope this helps
Posted on Jul 19, 2009
  • 81 Answers
SOURCE: MTD JE145H cutting deck keeps throwing belts
Usually the reason a mower deck is throwing its belts is there is a bearing that is starting to sieze up in one of the quill assemblies, which is the assembly that the blade is attached to . Either that or one of the belt tensioner pulleys is starting to go bad, easiest way to check this is remove the drive belt, take off the cover over the tension belt and remove that belt know check all moving parts for tightness or excessive looseness. Hope This Helps You Don
Posted on Dec 03, 2009
I have just bought an old MTD ride on and can't make the model number out. I can get 13AS678G870 or 13AS0780070. Just wondering if any of these numbers are close. It has a 42" cutting deck. Thanx
I had a mower like that and i always checked on line sears parts will help if not punch in make and those noumbers and you can find out just stick waith it try sears parts first hope i helped.
Mar 27, 2017 | Mtd Garden
Blade route
I can't give you an answer on this without knowing the model number of your mower.
Sep 25, 2013 | Mtd Oem Deep Deck Belt 46"
Replacing a MTD spindle assembly
Yes, most spindles come with non threaded holes. The metal is soft and you can just use regular bolts. Once you start them, they cut their own threads.
Jun 02, 2012 | Mtd Garden
I need a detailed diagram for replacing the mower deck on my Troy bilt 42" Pon y tractor.
It is the reverse order of cutting deck removal on page 22 of the manual below.
http://manuals.mtdproducts.com/mtd/Safety.do?BrandCode=10001&pid=243424&model_num=13WN77KS011&serial_num=TB24HT&filename=769-05435.pdf
If the manual is incorrect go to this site:
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10001
Enter your model AND serial number and then download the manual. Look for deck removal procedures and then install it in reverse order of removal.
Thanks for choosing FixYa,
Kelly
Aug 25, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
LA110, 42" mower deck, 1
Check that the cutting tip of the blade that is cutting lower is not bent down. Also park the mower on a level surface and lower the deck and check the gap under the front of the deck is even. If not, there are levelling adjustments on the top of one side of the deck. Regards Phil
Apr 15, 2011 | John Deere 195HP Hydrostatic 42" Cut...
When replacing double stack drive/deck pulley,how do you keep it from scraping deck/20 hp,46 cut,02 model,yard machines??!
MTD part number 950-0960A This is a spacer that goes under the pulley stack. It should help to keep the pulley from rubbing on the deck. Hope this helps.
Apr 01, 2011 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
I have a mtd 13.5 horse 38 inch cut 6 speed its around a 2007 or a 2008 i need to se how all the belts go on the mower deck and drive
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
May 02, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
