Question about Samsung VP-W90U Camcorder
BLACK SCREEN IN RECORD MODE
I CAN PLAY BACK TAPES IN PLAY BACK MODE BUT IF I PUT IT IN RECORD MODE, THE SCREEN IS JUST BLACK. I HAVE TOOK THE LENS CAP OFF! AND IT PLAYS BACK THIS WAY TOO. IT ALMOST SPOILT MY HOLIDAY AS IM MAD ABOUT RECORDING ON MY HOLIDAYS.
  • Anonymous Dec 25, 2008
    I have the same problem with a samsung minidv camcorder (scd-103).
I have the same problem faillure of the CCD-chip. when your camcorder is produced between 2000 and 2004 you can have this problem. Problem also known in other fabricats ( sony etc.) Sony repairs it for free. Samsung refuses this
Posted on Aug 27, 2007
SOURCE:
The camera is not showing a picture on the camcorder screen or tv when trying to play in play mode. It ate a tape when I tried to play back a video. I took out the tape, fixed the tape and then tried a...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 22, 2011 | Canon ZR600 Mini DV Digital Camcorder
Erasing the tape on a sony handycam vision please
Well the cheapest way is to go into record mode, cap the lens with the black lens cap and record a 'black' picture on the tape. This will erase all the pictures on the tape and leave you with a 'black' screen on the whole tape.
Oct 05, 2009 | Sony Handycam CCD-TRV37 Camcorder
Lens Cap Error
You have a defective CCD imager - the part of the lens that receives the image. Will need to be replaced.
Aug 03, 2009 | JVC GR D650US camcorder
Muddy image on screen and recorded
You are in luck. Sorry for the trouble but your model Elura 50 still has the CCD advisory from the factory for free repair. Send it in for CCD advisory before it is too late! When all functions are working but has distorted image in camera mode is due to CCD chip. Good Luck -James. for further assitance email, go to www.camerarepairjapan.com
Mar 24, 2009 | Canon Elura 50 Mini DV Digital Camcorder
Canon zr-90
call 1800-ok-canon same thing happened to me they fix it for free. its a recall on their side. you get you camera back in about two weeks. good luck
Sep 26, 2008 | Video Cameras
In Camera (Record) mode, does not show video at all, black screen
THIS IS YOUR CCD.. SAMSUNG IS VERY AWARE OF THIS BUT STILL CHARGES A ARM AND A LEG
Feb 06, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Jan 20, 2008 | Video Cameras
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
Recording
This sounds like the CCD sensor is faulty ( this is the device that generates picture in both v-cams and normal digital cameras and sits behind the lens ). Playback is fine but no image ( or very 'noisy' image ) in capture mode. Easy to repair but one has to put a new CCD block in.
Sep 03, 2007 | Cameras
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Samsung VP-W90U Camcorder Logo
116 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
