Question about Garden
Lawn boy 10533
Blade speed very slow on start up. has to catch up to engine speed, then dies down while mowing
SOURCE: Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Posted on Sep 01, 2008
  • 413 Answers
SOURCE: mower starts but boggs down and then dies
Sounds like the air filter media is full of muck.
You need to clean it.
Everything should then be fine....
Posted on Jul 02, 2009
SOURCE: once engaged and start mowing, you can mow for
I have the same problem with mine and its not the air filter. I have a new filter and cleaned it and still does it. I even took the air filter off and it still does it.
Posted on Aug 18, 2009
  • 496 Answers
SOURCE: I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Posted on Oct 05, 2009
  • 38 Answers
SOURCE: Lawn Boy mower will not start. New gas and plug.
Is the plug getting wet? if not, try introducing fuel to the intake and attempt to start it again, the interlock on the handle works by killing the ignition fire and applying a brake to the flywheel, this should be a Tecumseh engine, carb troubles are quite prevalent on these, by substituting fuel to the intake you are acting as the fuel supply, if it starts and runs briefly you have confirmed a fuel system issue
Posted on Jun 01, 2010
Testimonial: "Thanks, we will give it a try."
GOOD MORNING, I HAVE A D140 JOHN DEERE LAWN MOW,IT RUN WELL WHEN NOT MOWING BUT WHEN ENGAGED IT SLOW DOWN AS THOUGH IT HAS TO CATCH IT'S BREATH LESS THAN THREE YEARS OLD
Make sure there isn't anything binding the deck belt or blades. Check the spindles for free movenent. If all that is good then it might be the linkage that is supposed to adjust the throttle when the engine is under load or it might be a carb issue...especially if you run ethanol gas in it.
Aug 27, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Mtdproducts com
This most often happens when you are mowing too much grass at once, or when the deck (or chute if you have a bagger) is clogging for some reason. Sometimes this is made worse by having dull blades. Usually mowing at a slower speed or mowing more frequently will help solve this. If the motor is struggling with the blades, these are usually the culprits. Clean your deck thoroughly, cut the lawn more often, or cut it slower.
In some cases, if your PTO belt may be worn, stretched, or need adjustment. When this happens, the motor will not slow down with the blades but will keep running normally and you may smell a burning rubber smell as the blades slow down.
Jul 16, 2013 | Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Mower starts but boggs down and then dies
Jul 01, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
A row of uncut grass left between blaces when mowing
THE answer that FINALLY worked for me. Torque the bolt that holds on the blade to the recommended torque specified in your owners manual (for my Exmark this torque is 120 ft-lbs). When I first used the torque wrench, i was quite surprised by the amount of addional force I needed to apply to reach 120 ft-lbs Exmark blades have a round blade hole with a washer and therefore, relies only on friction provided by torquing bolt to the proper torque to prevent slippage so that the blade rotates at the same speed as the spindle. When slippage between the blade and spindle occurs, blade tip speed slows leaving uncut grass.
Note: this solution will NOT work for mowers with a blade and spindle design which uses a positive means (e.g., a star shaped hole on the blade) that assures the blade rotates at the same speed as the spindle with no slippage.
Jun 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
May 23, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
