Question about Garden
Oil leak in Briggs and Stratton 24hp engine
Tractor is a Craftsman, about ten years old, and until now has performed well. Leak seems to be coming from the upper front of the engine, model # 446777' type # 0246-E1. Thanks in advance for any info you may have.
jgwhomeequip
  • 1902 Answers
SOURCE: 31p777 18.5 hp briggs & stratton valve cover leak
Both can cause problems. It is recommend that you do not go on a grade more the 10% for your safety and the safety for others around. But if the valve cover is leaking this can lead to major problems if not repaired on a timely matter
Posted on Apr 29, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
  • 760 Answers
SOURCE: I have a Sears Craftsman lawn tractor 917.256531
Make sure you didn't overfill oil. You can download a manual here: http://www.managemylife.com/mmh/owner_manuals/27208/CRAFTSMAN-Lawn-Tractor-L0808359?brand_name_search=917256531+CRAFTSMAN
You can find parts at www.searspartsdirect.com
Many manuals are listed on page once you look parts
Posted on Oct 02, 2010
  • 202 Answers
SOURCE: I just want an owner's
http://www.briggsandstratton.com/engines/support/operators-manuals.aspx?NTT=42A707-2238-E1
Should fix you right up.
Posted on Oct 05, 2010
Testimonial: "I am sorry if I sounded rude about the manual. I just could not find the right link. Thank you for your timely answer. I 'm sure this will work."
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Why is my 22 hp 42 inch deck craftsman rider mower oil leaking somewhere in th fron of the engine
i need more info where is the leak near also check oil level if its to full it will blow by to the intake
Jul 29, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My husqvarna YTH2448 with BS 24OHV ELS725 started knocking and leaking oil from right side. I guess it threw a rod? I want to get another 24HP motor and replace it. Will any other motor's bolt pat
most all motors will boltt up u need to make sure the crank is the same diameter and length besides even if it didnt bolt right up u can always drill new holes
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have oil leaking out my 491056 oil filter on my mtd lawn mower. I have not changed it in about 8 years could that be why it is leaking? or ? It is pretty much pouring out now. Was a small leak now a...
Change you oil and while you are at it change the filter. Do not run until you have completed. You risk engine damage by loosing too much oil while running it.
Jul 24, 2011 | Briggs & Stratton 491056 492932 Briggs ...
I had Craftsman lawn tractor given to me. It's about 8 years old and has a 17 hp Briggs & Stratton engine. I found oil in the carb, and I think it's ceased, because I can't turn the flywheel. Anything...
is there oil in cylinder head? if so engine could have been tipped over wrong way causing oil to run into carby and cyl/head....drain oil from engine and cyl/head and see if you can turn over by hand
Aug 08, 2010 | Craftsman Garden
My 24hp Briggs and Stratton ohv engine has bent push rods on one side. The top valve can be pushed in but the bottom one will not push in. Is the valve stuck in the open position? If so how can it be...
unable to answer if valve opened or not but does sound like ur bottom valve is bent or piston made contact and bent it to fix need to remove head and replace valve also need to inspect piston face is not damaged from possible contact
Apr 12, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
My 25 hp briggs is smoking and leaking oil. it
if the engine is ran quite a lot evey year the valves muct be adjusted. If not it will cause a head gasket leak which it sounds you have
Apr 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Jul 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
