Question about Sony mylo COM-2
The "hold" function is stuck
I cant access to any settings or funcion, by touch or button's access, the touchscreen is like freezzzz
welcomejee
  • 10594 Answers
SOURCE: SONY DCR HC21 touchscreen buttons/functions suddenly not working
yes, seems its flexible wire that is bad.
Posted on Jun 21, 2009
SOURCE: touchscreen will not respond to touching screen
I have actually the same problem , I can see the pictures , buttons and all , just like normal , but the screen doesnt respont to any touch command .
Posted on Mar 24, 2010
bullet_okarn
  • 108 Answers
SOURCE: Touch screen on cyber shot is only partially
the touch sensitivity of the screen must have some problem, if your camera is under warranty then u can probably get it fixed by the company, but if not then u need to replace the screen which will be the same suggestion as the service center guys. so if u want to do it yourself (which is a lot cheap & easy if u are good with delicate electronics), then hit me back. i will help u with the screen replacement
Posted on Apr 11, 2010
SOURCE: HVR-a1u - Can I access the menu without using the touchscreen?
Don't have an answer, but two of our Sony HVR-A1U have now lost touch screen function. I wonder if this is a common problem?
Posted on Jul 11, 2010
shajanrs
  • 890 Answers
SOURCE: hc 21 camcorder touchscreen problem
Please follow the troubleshooting steps provided below and check the operation:
1. Rotate the screen and check if that helps.
2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder.
2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder.
2. Disconnect AC power adapter.
3. Remove the battery pack.
4. Move the POWER switch to the CAMERA position for 15 seconds.
5. Move the POWER switch to the OFF position.
6. Reconnect the AC power adapter or reinsert the battery pack.
7. Turn on the camcorder.
Posted on Jul 07, 2012
Testimonial: "Hello, I appreciate your response. Rotating the screen was a quick help. Thanks!"
Garmin Nuvi 1300 touch screen not working
It sounds like you need your touchscreen replaced. The touchscreen is soldered to the LCD display, so the touchscreen must be unsoldered from the LCD display and a new touchscreen resoldered to the LCD display. Please do not attempt to do this yourself. You can easily damage the LCD display in the process. More information about touchscreen replacement can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Apr 21, 2013 | Garmin nuvi GPS
Tip
How do I Unlock Parent Blocks on an iPod Touch
<p>If you are the parent of a child who uses an iPod touch, you have limited functions of the device. For example, you may not want your child to watch YouTube videos without supervision, or you may want to avoid it to surf the internet and be exposed to potentially inappropriate content. You can also turn off the iPod touch is able to transfer music, videos, games and applications, some of which you must pay to download. Alternatively, you can delete individual blocks, while other applications blocked applications. <br /> <p><br /> <p>1. Press the "Home" button below the touchscreen iPod touch. <br /> <p><br /> <p>2. Tap "Settings" app. <br /> <p><br /> <p>3. Tap "General" and then "constraints". <br /> <p><br /> <p>4. Enter your password when prompted. "Limitations" is displayed. <br /> <p>5. Touch the "ON / OFF" switch to the right of all the applications you want someone with the iPod touch can access the "ON" is selected. <br /> <p><br /> <p>6. Press the "Home" button below the touchscreen iPod Touch to return to the home screen to save the settings and return to the home screen. <br />
on Aug 09, 2011 | Apple iPod touch
Bernina 165 touchscreen not working
It sounds like you may have two problems - one is easy, but without the other, its hard !!! If the touchscreen isn't working, it may simply be mis-calibrated and cant be accessed. To recalibrate the touchscreen from scratch, switch the machine on whilst, at the same time, pressing both of the two needle position buttons - the calibration screen should then come up and you should touch the screen where the dots are shown to recalibrate it. If, pressing the dots does not do anything, the probability is that your touch overlay or main control board is faulty, in which case you will need to take it to your Bernina agent. If you manage to re-calibrate the touchscreen OK, switch the machine off and back on again and if the display is still very grey but readable, you can adjust the contrast of the display by pressing the button with an arrow facing right, inside a box - this will take you to the user adjustment menu. Touch the display button that has a symbol with three vertical bars of different shades of grey and this will take you to a display that allows the brightness and contrast to be adjusted - touch the up or down buttons to get the best display contrast and once this is done, you should be all working again. Good Luck
Jul 02, 2012 | Sewing Machines
Touch screen stuck 3ds wont turn off
If the 3DS ever freezes up on you (it's happened to me a few times now), press and hold the power button for about 10-15 seconds, it should force it to cut the power entirely without requiring you to touch the touchscreen.
Aug 22, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
Gps ' s touchscreen is stuck
If your touch screen is frozen, force a restart by holding down the power button until restart, then connect to computer and check for errors.
Jul 13, 2011 | Garmin GPS
The touch screen wont function with touch of the fingers.
Touchscreen not working
Clean the screen with a microfiber polishing cloth.
Do not wear gloves while using the touchscreen.
Do not use the touchscreen with wet hands or immediately after applying hand
lotion.
Moisture affects touchscreen behavior in the same manner as it affects a
trackpad.
If you have a protective plastic sheet or film on the touchscreen, try
removing it, because it may be preventing the touchscreen from working properly.
The current application may be unresponsive; press and hold the Sleep/Wake button
on top of iPod touch for a few seconds until a red slider appears.
Then press and hold the Home button until the application quits.
If that doesn't work, turn the device off and turn it on again. Press and
hold the Sleep/Wake button on the top of the device for few seconds until a
red slider appears, and then slide the slider.
Then press and hold the Sleep/Wake button until the Apple logo appears.
If the device did not turn off, reset it. Press and hold the Sleep/Wake button
and the Home button at the same time for a least ten seconds, until the Apple
logo appears.
Please rate me
Dec 07, 2010 | Mach Speed T3000 MP3 Player
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
Sony mylo COM-2 Logo
20 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
