Question about Akai Mpk49 Mpk 49 Key Midi Controller + Cubase 5 Full!
Akai mpk49 serial number
Cant find my serial number
I have the warranty no for a kimball upright piano 848943 what can i find out
nothing from us as we do not serve Kimball check with them
Jun 02, 2015 | Music
I have a Yamaha 12 string fg230 red label,575925 .what year was it made?
here is Yamaha 's Serial Number Wizard site. Yamaha Corporation of America
Also check out here..this is even better
Serial Number Chart For Acoustic and Classical Guitars
But in looking your number up I cant find a reasonable explanation. No letters...and there are 6 digit numerical numbers but they dont match yamaha's codes...I would call yamaha and talk to a tech at 1 (714) 522-9000 Good luck
Feb 26, 2015 | Yamaha Music
Can i find out the age of my eko guitar from the serial number
Unfortunatly, once you get past the well known Fender/Gibson/Gretch brands, info gets harder to come by.o can try contacting Eko directly in Italy. Here's a link
Numark Marshall Dunlop Korg PRS Akai Sonor EkoMusicGroup distributore di...
Or you can date the guitar off the codes on the pots. Here's some info on that-
Vintage Guitars Info dating vintage guitars amps by date source code
Feb 21, 2015 | Music
Some keys on mpk49 do not play unless hit hard
sounds like dust, if you know some one with an air compresser ask them to give it a blow through, if not then it is down to caned compressed air, if that is not enough, you need to open it, and clean the contacts (DVD cleaner is cheap and good)
Aug 29, 2014 | Akai Mpk49 Mpk 49 Midi USB Keyboard With...
How to fix usb port on keyboard controller
I am assuming that you broke the connector off the pcb board? you need a soldering iron about 30W and solder and flux, to remove and short circuit after you solder them back on, using a magnifying glass to make sure none of the 5 termnials are shorted
Squier serial numbers
According to my Squier book the IC prefix is Indonesia and the first two numbers are the year of production. So it seems to be a 2000 or 2001.
Aug 14, 2014 | Fender Musical Instruments Corporation...
When i play the keyboard and record it. it does not playback what i just performed when i record drums it plays back fine only the keyboard. im using the mpk49
I'm not familiar with Reason 5, but many midi track recorders need each instrument assigned to different midi chanels to be heard back. Check the manual in how to assign the midi tracks. Also, the playback has to be through a unit that is multi timbrel capable. Good luck!
Aug 17, 2011 | Propellerhead Reason 5
How do i make my mpk49 pads work with samples, in other words, when i press the pad once the loop will play or the sample will play all the way threw, but right now when i press the pad, it only plays how...
Have a look in your manual at the sections on Note Repeat and Time Division.NOTE REPEAT] – Holding this button while
striking a pad causes the pad to retrigger at a
rate based on the current Tempo and Time
Division settings. The Note Repeat feature can
be synced to an internal or external MIDI Clock
source. [NOTE REPEAT] can function as a
latching or momentary button
19. [TIME DIVISION] – This button is used to specify
the rate of the Note Repeat and Arpeggiator
features. When [TIME DIVISION] is activated,
you can press one of the 8 switches to specify a
time division. [TIME DIVISION] can function as a
momentary or toggle button.
Please note that while [TIME DIVISION] is active,
the 8 assignable buttons will not function as MIDI
CC or Program Change switches until [TIME
DIVISION] has been de-activated.
20. [ARP ON/OFF] – This button enables and The manuals and updates can be downloaded here:http://www.akaipro.com/mpk49 Please let me know if this helps.
Nov 30, 2009 | Akai Music
Akai Mpk49 Mpk 49 Key Midi Controller + Cubase 5 Full! Logo
243 people viewed this question
Top Akai Music Experts
Michial Gueffroy
T-Comtech Repairs
T-Comtech Repairs
Are you an Akai Music Expert? Answer questions, earn points and help others
